Question about Samsung LN-T4665F 46 in. LCD Television
I need a replacement screen for my LNT4665F. Where can I go
I have a replacement screen shipped directly from Samsung with original invoice. We ended up not using it. I am going to post on ebay shortly unless you would like to buy direct. The invoice says, "this part may be new or reconditioned" - so I am assuming it is reconditioned. The invoice amount is $546.00. I will sell it to you for $175 plus shipping.
Posted on May 11, 2010
  • Kurt Annaheim
    Kurt Annaheim Sep 22, 2012
    Do you still have it? Can you tell me why you ended up "not using it"? Thanks
Why does Samsung tv go off and on continually on and off , no pic, no sound?
Samsungs have used inferior capacitors in the their power supplies for years. There was a bulletin that would fix certain models under a class action extended warranty. You may want to call Samsung with your model serial number and exact model-it may be one of these models- don't take no for an answer- if push comes to shove they will give you the name of a competent reapir center- google the information on the internet to see if it can be fixed for free- the parts are only about $15 if you buy the capacitors online and can find someone to replace all 6 of them it does require soldering them in and out. I have fixed 3 of them that people were throwing away-
Jul 31, 2016 | Samsung Televison & Video
Samsung LNT4665F screen goes black
due to the moisture on the board, the board short tracks some where and turns the screen black and goes off to avoid further damage.again it will work for sometime and will again go black due to short tracking.the solution for this is to dry your board completely with a hot air dryer and cover the tv to avoid the gathering of the moisture causing the same problem again.nothing to worry it happens most of the time when the humidity is high.dont even think of replacing anything your unit is completely fine and behaving normally.
pls do rate the solution
thanks.
regards.
fixya expert team
Sep 03, 2008 | Televison & Video
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Menu pops on and off for about a minute when i first turn the tv on
the self diadnostic program in the tv is going bad.. may be time to replace the tv or dont shut it off completely
Jan 21, 2014 | Samsung LNT4665F 46inch 1080p LCD HDTV
Over time, my 2007 Samsung LCD TV, model LNT4665F has developed random vertical pixel noise lines scattered throughout the screen. What could be causing this?
This TV is known for powersupply failures and this can be effecting the incoming voltages into the mainboard (AKA tuner board). This would cause the noise. Please have someone look into the powersupply and check that the proper voltages are coming from it. If they check out ok, you need to replace your mainboard.
Please rate if this helped :)
Mar 30, 2011 | Samsung LN-T4665F 46 in. LCD Television
Samsung LCD model LNT4665F went completely blank with no picture. I replaced t-con board today and now the t.v. is bright and greyish, has two vertical gray lines and screen images are colorless and...
It sounds like you did not properly reinsert the ribbon cables, also verify that you do have 12vdc feeding the T-CON board, you may have to clean the contacts on the connectors also.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Dec 30, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LNT4665F, small red dots on LCD screen when powered on
i've seen this several times. the power supply board is starting to fail. next symptom will be it will not turn on. call 1-800-samsung for nearest service center.
Dec 07, 2009 | Televison & Video
A few popping sounds and multiple on and offs for my Samsung
you have a bad capacitor in the power supply the can shaped device will have a puffed up or domed top, when you find it replace it with the value printed on the side
Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
Unplug for 30 seconds from it's power source and then try it again. If that doesn't work, call Samsung for further troubleshooting and have your model number and serial number handy. Please be prepared to tell them how long the line is.
Mar 30, 2008 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN-T4665F 46 in. LCD Television Logo
238 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
