Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
My mower won't do anything when trying to crank it. I had this problem a few week ago, i washed the deck free of debris, charged the battery and it cranked. I think that the safety switch for the blade engagment is bad. how do i check it?
    President:
  • 1,851 Answers
Remove the safety switch - place a voltage meter on both sides - if it is working - you should get current - if not - toss it get another and install.
Start engine Mow lawn.
Posted on May 06, 2010
  • 29 Answers
Pull the wires off the safety switch and plug a jumper into the 2 wires. then try to start it.
Posted on May 01, 2010
Why can' I t get mower to do anything when trying to crank it over?
try jumping your battery with your car/battery. If that works, charge your battery and/or adjust your valves. If it doesnt, try jumping directly to the starter from the battery. If that works, get a new starter solenoid. If it doesnt, get a new starter.
Jun 09, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
Mower won't start with ignition key
did you replace stater relay switch
Jul 09, 2013 | Garden
The mower is about 5 years old. The batterY is two years OLD and the tractor will start with a jumper battery box. When I try to crank the engine, the starter sounds like its binding but after a few...
Not necessarily the battery can be weak with a small internal failure and can cause the issue of shorting out and not staying charged. This is very common on small batteries for these mowers. The replacement batteries you get at the hardware stores are the worst culprits for going bad after just a year or 2. The main battery that comes with the tractor are usually much stouter than the replacements. Before we tear intot he charging system I would suggest a new battery or hook up a temporary car battery if you have one to see if the guage acts up, or if you have a volt ohm meter test the charging system by reading the battery as it is running. It should be between 13 and 14 volts if it is worrking correct. You can also use the old stanby tried and tested method of pulling the positve cable off the battery after the mower has been started and see if it stays running. This will give us a base to proceed from. Let me know what you have tried and what you find.
Nov 03, 2011 | Garden
When I crank mower , blades engage when I don't have them engaged!
The belt engaging mechanism is remaining partially engaged. Check the deck for debris and clean it off really good. Retry. If still occuring you may need to remove the deck to see if there is still debris there or to check for corrosion. With the deck removed, if all the debris is cleaned up and with and you can manually move the tensioning mechanism and see what the hang up is, it might just take a shot of wd40 and moving it by hand a few times to clear it up. If it is a rust thing then you are going to want to keep it lubricated and cleaned to maintain free operation. You should not have to remove the deck every time to lube it, you should be able to get the lube sprayed into there by reaching under once you learn just where your deck needs it.
If really helpful, please rate.
Jul 14, 2011 | Yard Machines Garden
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
Engine won't crank on a 18.5hp 4000. I checked mechanical interlocks, charged battery and put in fresh gas. New carb and fuel lines put in last year. When I turn the key, there is a click and the ammeter...
The starter solenoid is most likely the clicking you hear. It has contacts inside which go bad. These are about $10 and easily replaced. Just follow the + battery cable and it will lead you to the solenoid.
Jun 05, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
No power
I think you should check the charging system. You said you replaced the battery a few weeks ago. Even with the charging system not working, the battery might have enough power for a dozen or more start-ups; but using the lights may have drained what power was left. Get or borrow a battery charger and charge your battery. If mower then seems to be working fine, measure the voltage across the battery when the mower engine is running at normal speed (not idling). It should be 13.5 volts or more if the charging system is working. 12 volts or less means it's probably not working. Either test or replace the regulator/rectifier. Please rate me if you think this helped, thanks!
May 31, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Jun 30, 2009 | Garden
Won;t restart..
Check battery,if it's good, check charging system.
May 08, 2009 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
197 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
