Question about HP Pavilion DV6700T Notebook PC
When I turn on and hear buzz normal,and hear beep beep beep beep as screen still black
    Problem Solver:
  • 7 Answers
One of the memory sticks is loose.
Posted on May 01, 2010
Desktop turns on , doesnt beep, black screen, with orange light in front. instead of green
So if I understand you correctly when you turn it on you get the oraange light on the front, the sound of the fans turning but no beep and no video output?
If this is correct then you likely have a POST problem (Power On Self Test), the beep you normally hear is conformation that the computer has passed the POST correctly - if you no longer have the POST beep then I suggest you look up your motherboard manual for more info but the basic check is to confirm all the cables and drives are well connected, the RAM is fully and correctly inserted. If you have recently added any new devices to your computer (graphics card or RAM etc) then remove this and see if the POST problem goes away. You may also find in your motherboard manual something labeled CMOS Clear - this will be a jumper (little pins sticking out) of the motherboard which is essentially a reset for the BIOS which may help rule out an issue in the BIOS config.
Nov 24, 2013 | HP Pavilion Computers & Internet
Turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier http://advancecamera.com/repair
Jun 05, 2007 | Casio EXILIM EX-Z1000 Digital Camera
When i turn on my ps3 it turns pitch black using hdmi and and normal output. it has a green light as well it just is pitch black on the screen.
The problem could be that the video output settings don't go through the correct video cables. Here's how to reset those settings:
  • Hold down the power button for 5-10 seconds until you hear two beeps; then let go.
May 31, 2011 | Sony Playstation 3 (PS3) Console
A buzzing noise coming from inside the tv but still buzzes when on mute but doesnt buzz when tv guide is up on the screen or when a channel is showing what time it starts
plasma tvs buzz a lot, depending on screen brightness. its probably normal but if you can hear loudly over your volume, may be a bad board or plasma panel. from behind tv, left side = y board, right side = z board, middle = power board ---- bad panel can buzz from anywhere... if you hear all parts buzzing, its probably normal plasma noise
Jun 01, 2010 | Samsung Televison & Video
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Black screen no start up
nefaa_doudy
When you turn on your PS3 and you get a black screen but do hear the audio most likely you just need to reset the video settings on the system. You do this by holding down the power button until it beeps twice. After you do this try to turn on the system. If you still have a black screen then you need to check the connections.
Note if you never hear the audio then there may be a problem with the mainboard of the PS3. It is possible that the out put that you are using got burned out. You may try the other connection to see what happens. So if you normally use the AV connection then try the PS# with the HDMI connection and vice versa.
If you still have trouble I would check with Sony so see if you are still in warranty to get the system repaired.
Hope this helps
Issken
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
Problem with an Everex
this is hang-up on your Everex, check how many beeps you hear and we will identify the problem on your Everex 1500. See to it that your hear the Beeps on your Stepnote, good luck!
Jul 22, 2009 | Everex StepNote NC1500 Notebook
Samsung LN-t5265f picture turns off after a few seconds hear buzz
You have a bad Power supply. Have a trained Samsung tech replace the Power Supply.
Jul 02, 2009 | Televison & Video
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Pc problem
u have to do this remove your ram clean it & put it back
Jul 16, 2008 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
HP Pavilion DV6700T Notebook PC Logo
57 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
