Sharper Image CT412 Wireless Headphones stopped charging
Both the power light and the charging light stopped functioning on the headphone cradle. Is there a problem with the power cord?
5 Suggested Answers
SOURCE: connection
Hello I had the same problem as you, red LED on solid all the time. The fix is to hold the button down for 10 seconds or more and the red LED will go out. Continue to hold the button down for as long as it takes and after a while the LED will begin to flash reb/blue very fast. It's now ready to pair with the transmitter were once again you do the same thing, keep holding the on button down for as long as it takes to start flashing red/blue. Do this even if the LED goes out for a short while. Once you have then both flashing they will then detect each other and pair and go solid blue. Let me know how you get on.
Posted on Aug 03, 2007
SOURCE: logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Posted on Mar 19, 2008
SOURCE: My Bose Quiet Comfort Headphone Cord
Go to
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/accessories/qc3_replacement_audio_cable_acc.jsp
It even comes with free shipping
Posted on Jan 05, 2009
SOURCE: RCA wireless headphones
Hey, my rca whp141 is incredibly quiet. Go ahead and turn the volume up on the TV.
If that doesn't work make sure
  • The headphones and headset are on the same channel (like 1).
  • the transmitter is on and working (Power: GREEN LIGHT)
  • the headset is on and working (GREEN LIGHT)
  • the headset is receiving a signal (St: GREEN LIGHT).
Hope this helps.
Posted on May 30, 2009
I can't get sound through my headphones on my Bravia kdl-52xbr5 tv. First time I have tried to hook up the headphones which are sharper image wireless
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Dec 16, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
Left side of my sharper image ct411 doesn't work at all.
Check your cable and make sure there aren't any frayed or cut wires. If your cable looks good, then open up your headphones and make sure the connection to each speaker is correctly soldered. Sometimes when you expand/contract the size setting on these headphones it pulls the wire until it eventually disconnects. I hope this helps!
Aug 31, 2010 | Sharper Image (CT411) Consumer Headphones
The operating instructions say that after 16 hours the red power/charge indicator light would go out, indicating the batteries are fully charged. After 3 days the red light on my unit is still on. The...
I have the MDR-RF970R but I bet the battery is the same. If you have had the headphone for seceral years then I bet you are right, the battery is going. You might try using them till the battery dies and then recharge. This is called deep cycle and may time it will extend the life of rechargables.
If the headphones are new, then just check and make sure that they going all the way into the charge slot.
I will say it is not common for me to see the light off, but I use the headphones all the time.
Good luck.
Apr 30, 2010 | Sony MDR-RF970RK Headphones
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
Sharper Image CT411 head set batteries?
you peal off the soft part of the headphones that cover your ear you'll see the battery compartment from there
Feb 25, 2009 | Sharper Image (CT411) Consumer Headphones
Batteries
You need to remove the rubber on each side of the headset - and you will need to replace one "AAA" battery on each side - hope this helps
Aug 25, 2008 | Sharper Image (CT411) Consumer Headphones
My headphones won't charge.
Remove the rubber caps and replace the two AAA rechargable Ni-MH batteries.
Aug 15, 2007 | Sharper Image (CT411) Consumer Headphones
342 people viewed this question
 Grubhead
Grubhead
