Question about Tippmann A 5 Standard Paintball Gun
How do I put my alpha black tactical back together?
How do I put my alpha black tactical back together, its hard even with the manual..
    Novelist:
    Scholar:
  • 111 Answers
Best advice... check out your local field or Airsmith. They probably have a few Alphas around and in any case would be able to walk you through it, and you have a perfect opportunity to ask questions as you go!
Play hard, play safe, play with honor!
8^)
Posted on Jan 04, 2011
I have a semi auto alpha black. When im firing on semi auto sometime the gun switches quickly to fully auto and releases lots of CO2 without really shooting any paintballs
Does this only happen when you're low on air? Also, make sure you're using a good paintball oil for lubrication and make sure the marker is clean. It's possible for an o-ring to leak, or once it gets cold to leak, so make sure you use the proper o-ring for the proper location (lots of them look alike so keep them labeled and bagged separately).
8^)
Aug 19, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
My alpha black paintball gun is shooting 1 to 5 then stopping.
Sounds like it needs to be oiled. A couple of drops in the small hole where your bottle screws on.
Replace bottle and dry fire to see if you got it. Cleaning is just as important. Internals need to be cleaned
and lubed often. I know it's late but hope it helps someone.
Jun 11, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Paintball gun problem
First off, make sure it's clean, and lubed with a quality oil made for paintball.
If you're sure the o-rings are good (as in relatively new) it's pretty hard to tell just from looking as it doesn't take a lot of damage to leak air.
Try a different tank, just to be sure. Make sure it's full.
**** it. If that stops it there's a clue.
If it's had some use it's possible to have a bad/weak spring and the valve isn't closing entirely. Make sure your velocity is less then 300fps.
Check out your local airsmith or field and they should be able to get you squared away if none of that helps.
8^)
Apr 30, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Took it apart and don't know how to reassemble
How To reassemble an Army alpha black paintball gun.
Apr 23, 2010 | Tippmann 98 Custom Act Paintball Gun
I took the cover almost off and now don't know how to put the harness back together
have you received an answer yet??? I have had to take off and put back on mine at least 10 times now.....If you still don't have an answer I will take mine apart and re-cover and write steps down as I go....it is a hard cover to take on and off....it still takes me about 20mins to get it all together....you may want to consider buying a easy remove cover to go overtop of your pre-existing one. Let me know if you need help
Jun 28, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
Need manual for Predator Board
Try this
http://www.alternativepb.com/manuals/tagdm4board.pdf
May 09, 2009 | Paintball Tippmann U.S Army Alpha Tactical...
Cant put the car seat back together
took the straps off and can't put back together
Apr 02, 2009 | Cosco Alpha Omega 22-180 - with Shield
Can't put back together
Please look at this manual instructions to get a clear help. and dont forget your rating for me. Thanks.
http://www.coscojuvenile.com/instructions.asp
Aug 21, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Tippmann A 5 Standard Paintball Gun Logo
110 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Vickie Miller
Vickie Miller
Level 1 Expert
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
