Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a 14hp Craftsman riding mower, Model 917.257550. I cannot get the blades to disengage when I pull the lever. It will go down about 3/4's of the way and then wont allow me to continue to disengage completely. The blades keep spinning, so I have to shut the mower off to stop the blades, then I can't restart. What can I check or adjust to eliminate this problem? Thanks
  • mchmielinski May 02, 2010
    I lubricated everything and it worked for about a few power on and offs. Now it's stuck again at about 3/4's disengaged. Which bars/arms/linkages should I be looking at that might be bent?
    Thanks
  • mchmielinski May 05, 2010
    I need a diagram of the linkage system for this mowerto understand what I'm doing. I can't tell what is what.
    Thanks
  • 17,970 Answers
Could be that the safety switch under the seat has gotten unplugged or the switch that is attached to the blade engage lever is unplugged or has gone bad but quite unusual for the safety switch to go bad.
Posted on Aug 09, 2010
  • 10,319 Answers
One of the rods are binding against another metal item surrounding the adjustment. You will need to lubricate the adjusting rods so it will release as it did before
Posted on May 03, 2010
  • 6 more comments
  • frank thomas wilson
    frank thomas wilson May 05, 2010
    Also check the tension release spring. I forgot to mention that for they do bind up as well
    frank thomas wilson May 08, 2010
    http://userguides.50webs.com/Craftsman%2...
    frank thomas wilson May 12, 2010
    I guess nothing was done as of yet. Did you remover the belt at all yet? If not try that and see if it works with it off. If not lubricate all moving parts and check the tensioner spring on the release arm. You have a binding item or rust causing this problem. I have owned many Sears riders and within 4 to 5 years they all had problems such as yours. I even had the belly of the blade cesction fall off from rusted gussets at the welds. After 25 years I switch to the John Deere brand. Cut 3 acres for 13 years without any problems with the exception of 2 oil changes per year and a new belt every 5 years
    I will search for a service manual for you
    Manuals on the web you can get
    http://userguides.50webs.com/manual.htm
    frank thomas wilson May 22, 2010
    MTD manufactures this lawn mower. The guage steel they use is half as thick of what a John Deere has. The metal does get rusted up and gets weak at all points so purchasing a quality brand of penatrating oil and lubricating the entire mechanism would greatly help your problems with this. You may have to apply several applications to this to make it work. Using a wire wheel brush or a wire brush to clean off all access of clippings on all parts is recommended as well be fore lubricating it
    If you believe the rods are bent they can be ordered at Sears. They do not cost very much. You can never bend them back into the original shape unless you have a new one to go by. Once you have new ones save the old ones and bend them to match the new ones. Save them for the future or return the new ones for a refund if you get the old ones to operate fine
    frank thomas wilson Jun 12, 2010
    You may need to get the blade deck off of this and clean it totally well to see what is binding. Usually the gusset the rods lock into will bind from wear to the inner brass bearing. If egged out of shape in the bushing the mechanisum can lock up on this mower
  • 524 Answers
The best way to do this is just lubricate all the slides completely. This unit will engage the blades by moving the pulley back and pulling the belt tight. If you look under your lever you will see a shift linkage, make sure nothing is bent or broken. Lubricate and tighten everything properly.
Posted on May 01, 2010
  • Alex May 03, 2010
    The only thing i can tell you from not looking at the unit is to follow the lever down to the linkage, make sure this is bolted tight and also make sure everything is straight. Then follow the linkage bars to the engaging pulley and make sure everything is tight and not worn or damaged. Dont be afraid to really spray some pentro oil or WD on the pulley or the linkage joints. Alot in never to much
Model 917.20381 riding mower. Why don't blades disengage?
Terry, Deck full of debris around belt tensioner not allowing it to release, tension arm seized/spring broke, wrong/small belt installed.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 42 MOWER REPAIR
My mower deck will not disengage
Blade will not disengage Craftsman 917 270662
https://answers.yahoo.com/question/index?qid=20090407155731AACRvsq
Sears Craftsman 917 272481 LTX1000 Riding Mower Deck Belt Blade...
Apr 08, 2016 | Craftsman Garden
Release blade engagement attachment lever craftsman #917259330
there sure be a lever to disengage on the fir =e wall of the lawn mower deck or near fire wall o the lawn mower
Oct 16, 2014 | Garden
Blades wont disengage completely
The lever has worn out....thus it is not locking up immediately when fully disengaged. You'll need to trace down the lever right down to the blade mechanism and then you'll notice a fork shaped part that shows signs of wear....very common on craftsman riding mowers.
Dec 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades won't disengage.
If this is a riding mower, then check the cable tension around the belt. I have a craftsman and when I take the deck off for the winter, there is cable under there that controls the blades from going. You can follow the cable down to the blades it usually is under the hood. When you are on the bottom have someone control the lever and see if it tightens and loosens the belt (do not have the mower running!). A axel should move to tighten the belt to turn the blades and when you pull the lever to stop the blades the axel should move to loosen the belt. Hope this helps. Oh from there the cable could be snapped, which is a 35 to 65 dollar part. Also could be the axel itself has something faulty where it doesn't move.
Oct 15, 2012 | Garden
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Blades running while the lever is disengaged
sounds like belt is to tight or the electric clutch isn't disengaging
Jun 25, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
After replacing the belt, new pulleys, and bolts, my mower wont disengage the blades when i disengage the lever. when i start the mower, the blades are off, but once i engage the lever, they start, but...
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Oct 17, 2009 | Craftsman Garden
Blades will not disengage
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Oct 08, 2009 | Craftsman Garden
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
493 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
