Question about Dryers
Need to locate the heater for the Maytag Dryer M#DE308
  • Dryers Master
  • 8,220 Answers
Unplug the dryer, remove these screws. Get the front off. The heater will be in a mailbox. Note: The element cost around 10 bucks you do not need to buy the whole mailbox which could be way expensive.Need to locate the heater for the Maytag Dryer - f9f5c6b.jpg
Posted on May 04, 2010
  • Dryers Master
  • 43,501 Answers
Here is a tip that will tell you just how to do that...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on May 03, 2010
Where do I buy belt for Maytag de308 dryer?
There are various different appliance parts suppliers that you can find online to purchase a belt for your dryer. A couple of them are Sears parts direct, repairclinic.com. You could also check locally to see if you have a repair parts place in your town.
Apr 30, 2015 | Maytag Dryers
I cannot figure out how to get my Maytag DE308 apart to replace my dryer belt.
Two screws at the base are removed first (after yall unplug the dryer)
Your belt is a 312959
It goes back on like this:
Notice the slick side of the belt goes to the drum.
Get the belt down in the groove on the tub and you will have trouble.
Use zoomspout oil to lube the rollers and idler. It is safe for dryers and can be purchased at Ace hardware stores. Clean her up and party on!
Aug 07, 2011 | Dryers
So we have a Maytag DE308 and for some reason whenever we try to push the dial in to turn it on, it buzzes but will not start. Any ideas as to what this could be?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 28, 2010 | Dryers
How do i change the belt on a model No. DE308 maytag dryer
Hi
To change the belt you'll need to remove the top paenl and then remove the drum and you would be able to see the belt. You can disassemble it by the following procedure--
Drum Removal / Roller / Glide Access--
  • Disconnect power supply to unit.
  • Remove Top Cover and Front Panel,
Top Cover / Door Switch / Front Panel /Gasket Removal-
1. Disconnect power supply to unit.
2. Use a plastic putty knife to depress the locking clip between the Top Cover and Front Panel.
3. Disconnect wiring from the Door Switch.
4. Depress the locking tabs on switch side and remove through the front.
5. Remove two screws, 1 each side, from the back flange of the Front Panel.
6. Tip Front Panel back and remove. Rotate Front Panel to the back side and remove gasket.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Dryers
My Maytag Dryer model DE308 takes 2 hours to dry a load of clothes. I have air flow, but after an hour, the clothes are still damp. THe dryer does not have the heat that it used to. I know that with the...
Good day,
Your right on the heating element.
If your positive the vent system to the outside is clean, then
Remove the front panel of the dryer, and inspect the blower wheel. If worn on the shaft(slipping), it needs replaced.
2. Remove the whole front panel to access the blower housing and the chute going to the lint filter. Clean as needed. (common problem).
3. If everything checks clean, then the thermostat that is mounted on top of the heating element canister is the most common problem but is only one of the thermostats.
Maytag uses a lot of air versus heat for drying. That is why it is important that part of the system is correct.
Mar 14, 2010 | Maytag Dryers
Maytag PYE2300YW will not turn
maytag performa's have a thermal fuse located by the heater element located under the top back left corner
Also check for correct voltage to dryer
Nov 04, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Atlantis dryer no heat
The heating element and thermostat are located behind the front panel of the dryer. you will need to remove the door, then the retaining screws. the heater / element is located on the left side as you are facing the front of the dryer and has to sheet meta screws (upper back top / and front bottom) which will need to be removed. the unit has several colored wires for the thermostat and switch. remove these (remember which goes where) and the enitre unit will come out easily.
Aug 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
