Question about Fisher and Paykel GWL11 Top Load Washer
FISHER & PIKEL SMART DRIVE 601
The cold water fill is very slow . I refered to the solutions for the similar problems to check the hot and cool water flow from faucet, clean the screen and filter and take out the rubber gasket in the water inlets. But after that nothing is improved. Does it mean the valves failed or what? If they are, how much for replace them or whole box as valves are sealed in the box.
Thanks
JOHN
  • Fisher and P... Master
  • 5,568 Answers
Typically, this problem is caused by the failure of the electrically controlled mixing valve. I don't know your machine but on the majority of all washers, the H/C hoses actually connect to the body of the valve which is often held in place by one or two screws and has 2 or 3 quick-disconnect push-on connectors. Once the back panel is removed, you should be able to see the valve body right inside of where the hoses were connected.
Posted on May 01, 2010
Machine wont fill with hot water
problem in hot water tap
hot water solenoid not activating to let water in
to prove either switch the hoses on the taps and press cold water wash
that proves the tap
then press hot wash and that proves the solenoid
Jul 21, 2016 | Fisher and Paykel Washing Machines
Fisher & Paykel smartdrive 053 fills really slow
Your cold valve could be faulty & need replacing.
Try swapping hot & cold valves to see if it fills faster.
Jul 12, 2012 | Fisher and Paykel Washing Machines
I have a Fisher & Paykel Smart Drive 601 washing machine. It will do a cold wash with no problem, however when i try to do a warm or hot wash, after about a minute of trying to draw water into the...
Check your fill lines going into the washer, my guess is the hot line is filled with junk. They have screens inside the end of the fill lines that get loaded with gunk, clean off the screen & your good to go
Nov 08, 2010 | Fisher and Paykel Washing Machines
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing machine slow to fill
yes or a water pressure issue, mosty when using hot or warm
May 19, 2010 | Fisher and Paykel Active Smart E522B...
Fisher & paykel smart drive 601, power to board, won't fill
If it isn/t doing anything at all it could be a faulty start switch on the display panel. Also make sure you can hear an audible click when you open and close the lid. The lid switch on a 601 is actuated on the right hand back of lid adjust as required. Hope this helps.
Oct 20, 2009 | Washing Machines
Fisher & Paykel Smart Drive 601 - won't turn on
Hi I Have this washing machine (FISHER & PAYKEL Smart drive 601) hasn't been turn on for 4 yrs. now I'm going to use it coz my other machine broke.when I turn it on ,at starting it only distribute a little amount of water then it span the drum slowly.after about 5 mins. The lights of cold and hot keeps blinking and beeping.sounds like an error beeps .The power and all the light button still on except the cold and hot lights keeps blinking then just stop workin. can u help me what the problem could be.
Thanks
Jaf
Jan 17, 2008 | Washing Machines
Fisher&Paykel Smart Drive 601 Both Hot and Cold Water Fill very slowly
Hey there. I've had the same problem recently. It would fill slowly, and then after a while, it wouldn't fill at all. So I got some a new valve. it cost about $NZ30 delivered. You'll need one each for hot and cold. You can get parts from http://www.primedistributors.co.nz/. I think the part you need is 426142. you can check an image of it on the website. Good luck.
Aug 17, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
265 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
