Won't power up
Hi, I have had the Sansa M240 for about 6 months and it works great. yesterday when I was trying to turn it on, it wouldn't power up. I pressed the power button for longer than I normally would, and it still won't power up. I changed the battery, but it still stays off. When I got home, I hooked the machine onto my PC and the LCD screen shows that the MP3 player is connected, and the machine stays on and I could turn it on and off. However, this morning, I tried to turn it on, it wouldn't power up again. I hooked it up to my PC again and it worked again. Would you please try to explain what is wrong with the machine? Thanks! won't power up
  • 242 Answers
There are more people around having the same problem. The player doesn't work anymore after a few weeks or months.
Think the best you can do is use of your warranty...and try to get a new one.
Posted on Mar 25, 2008
SOURCE: Won't power up
I had the same problem- it would lock up, the computer wouldn't recognize it, etc., etc. I ended up emailing sandisk tech support. they gave me the same routine the other responder gave, but that didn't work either. COnvinced it was defective, I returned it to sandisk, who gave me a replacement. i would suggest you do the same- its probably defective.
Posted on Jun 10, 2007
  • 626 Answers
SOURCE: How to download the software of SanDisk Sansa m240 MP3
You dont need any specific drivers. As long as you have Windows XP / SP2 and Windows Media Player 10 or higher. The drivers are part of these required components. Best of Luck.
Posted on Sep 06, 2007
  • 3037 Answers
SOURCE: i need the installation disk for sansa m240
The player has 2 modes. MTP and MSC or something like that. Check the menus on the device and set it to the other one.
MSC is what worked for mine
Posted on Mar 18, 2008
  • 3037 Answers
SOURCE: toget soft ware
You don't need external software for the m240, everything should be on the player, check that when the USB is connected that is says MSC if you are having problems with the connection otherwise if you have a different problem or can be more specific, let me know
SOURCE: reset
what a *****! the last person
Posted on May 17, 2008
My Toshiba laptop won't turn in. Yesterday I was
Unplug, remove battery, plug in reboot. OR, try a System Restore to a date before this issue. Have you cleaned the fan, vents, heatsink recently? Is it overheating? It would be helpful if we knew the Toshiba Model number and the OS you are using.
May 06, 2013 | Computers & Internet
How to unfreeze mp3 player
I would recommend you to upgrade your device firmware.
This will fix the issue.
Jul 04, 2008 | SanDisk Sansa e250 MP3 Player
My Sansa Media Converter won`t download videos or photos into my Sansa Fuze 4GB.First when I installed the Sansa Media Converter it wouldn`t recognize my Sansa Fuze.After a lot of research on the Internet...
Google a program called
Video Download Studio
then you can use it FREE download video or audio form YouTube, google, metacafe, redtube, dailymotion etc. attention: download function is no need to register
you can also use it to convert video to audio, video to video, audio to audio.
use it convert video to mp3 mp4 for your iPod
Jun 16, 2010 | SanDisk Sansa e260 MP3 Player
My device turns on but shows message ¨refresh database¨ it won´t do anything else, what can do?
Try these steps:
  STEP 1 - Reset the device
1. Slide the Power switch up and hold it for approximately 20 seconds.
2. Release the Power switch once the device is powered down.
3. Turn the device back on.
STEP 2 - Download and Install the Sansa Firmware Updater
Jan 29, 2009 | SanDisk Sansa e260 MP3 Player
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
Sansa e270 ; stuck in recovery mode.
Attention: Resetting the device will delete all the songs
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Jun 18, 2008 | SanDisk Sansa e270 MP3 Player
Won`t turn on
Try leaving it unplugged for longer period of time. Look on the remote for any possible reset function. Try power button without the remote. If any ot these doesn't work there is a power supply module inside that malfunctioned. If under warranty contact where you purchased it. If not under warranty if you can get the module it is a simple plug up procedure.
Dec 31, 2007 | LG 42LC7D-UB Television
Won't turn on.
Fixed my "dead" Sansa by opening the back, removing the battery then putting it back in. This appears to have rebooted the system and now it's working fine. No files were lost.
(I did try holding down the on/off button prior to this but got no response at all.)
Dec 27, 2007 | SanDisk Sansa E280 MP3 Player
My screen froze when i started a video. how do i unfreeze it?
the same shit happened 2 me yesterday night. this is the second time it happend. the screen is blank but it still has alight. this morning i noticed that that light went off so i turned it on and it worked but it said battery too low so i charged it and its working. so give about a day to see iff it works, and i hope it works for u
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
48 people viewed this question
