Question about Canon PIXMA iP1500 InkJet Photo Printer
Says paper stuck, have cleared paper stuck and pressed OK still says paper stuck
  • 4,041 Answers
Hello there I would still try this. then you will be sure it clear.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 01, 2010
SOURCE: Paper Output Slot
Hi John,
Some small piece of paper or something stuck in the printer path, remove the paper feed tray and clean it completely , open the printer cover and clean any particles, try cleaning the printer head path also... if nothing is visible try using a torch light and then clean it from inside.... once done with all cleaning switch on the printer, things should be fine now... if not
Please get in touch with canon service center, if the printer is still in warranty, or try to contact local serive center....
Hope this answers your post, please let me know by providing your valuable feedback....
Thanks,
Robosoft.
Posted on Dec 24, 2007
  • 9 Answers
SOURCE: paper jam
There is an end of form sensor in the paper path that is likely stuck or the rollers cannot turn due to some other Jam. The machine will throw that message if those two mechanisms cannot function. Look for debris in the printer - give it a good shake.
Posted on Oct 10, 2008
robshow
  • 367 Answers
SOURCE: Paper Jam message
This can be cause by the smalles piece of paper. Try using compressed air to plow out any dust or small papers that may be near the sensor. Then unplug printer and plug back in.
Posted on Jan 07, 2009
rockfixya
  • 679 Answers
SOURCE: HP c4280 says carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
  • 3 Answers
SOURCE: Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Posted on Oct 09, 2009
Xerox phaser 6130 is stuck in 8.5 x 11 -- we need A4
When loading paper in the Paper Tray set the paper type and size on the Control Panel before printing.
NOTE: If [None] is selected in the Paper Type pull-down menu in the print driver, printing will default to the Control Panel settings. Printing will be performed only when the settings for the paper size and type configured in the print driver match the settings on the Control Panel. If the settings in the print driver and Control Panel do not match, follow the instructions displayed on the Control Panel.
To select a paper type:
NOTE: Paper type settings must match those of the actual paper loaded in the paper trays; otherwise, image quality problems can occur.
  1. Press the [Menu] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until 'Tray Settings' is selected on the Display Screen, and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select the tray, and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button until 'Paper Type' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select the correct paper type for the loaded paper, and then press the [OK] button.
  6. Press the [Menu] button to exit.
To select a paper size:
  4. Press the [Up] or [Down] arrow button until 'Paper Size' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button until the correct paper size is selected, and then press the [OK] button.
Jul 06, 2010 | Xerox Phaser 6130 Laser Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
I have the following error message:
SOMETHING MOST LIKELY FELL DOWN IN BACK PAPER PATH OR TORN PAPER THAT HAS PAPER SENSOR STUCK. HARD TO SEE SOMETIMES. MIGHT WHAT TO TURN MACH UPSIDE DOWN AND SHAKE BE VERY CAREFULL
Apr 14, 2010 | Canon PIXMA MP830 All-In-One InkJet...
It thinks it is jammed when it is not
there has to be a tiny piece of paper stuck in there some where. It can be a very small piece. Check again, use a flash light if you have to, to get a really good view.
Nov 20, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Message reads: the paper is jammed clear the paper and press OK
Even if a small piece of paper stuck inside the printer you ll get this msg.  So what you have to do is if you have a Air blower or vaccum cleaner blow air inside the printer,  If any piece of paper is stuck inside it will come out and you won't get that msg again.  Try this and sure it will work...!
Mar 18, 2009 | Office Equipment & Supplies
Canon PIXMA iP1500 InkJet Photo Printer Logo
144 people viewed this question
old marine
old marine
