Faulty Charger i have a fujitsu P12515 laptop which i think has a problem with the charger or the battery because it takes hours to charge and if i unplug the power cable then it turns off.
  • 4,234 Answers
If the unit works with the charger plugged in, but not with the battery, the most likely problem is the battery itself. Replac the battery. While possible, it is rare for the charging system to fail within the laptop. Let us know if the new battery has problems.
Dan
Posted on Mar 25, 2008
Problem with USB Charger Doctor
May be your USB charger faulty.If very old better replace.
Sep 22, 2017 | Cell Phones
Acer laptop 5551 wont charge
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Aspire 5551 AC Adapter 65Watt 19V 3.42A
Feb 17, 2013 | Acer Aspire Computers & Internet
Battery charging but laptop won't work while plugged in
The purchased is sub standard. Get a replacement from the store. N.B the fujitsu charger will work for some
Time and damage your laptop because of the higher amp
Jan 27, 2013 | Toshiba Satellite Computers & Internet
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Fujitsu n3410 wont charge
Unfortuneately that leaves the charging circuits on the motherboard that must be faulty, "this is so rare I have seen only one in all my years of service". But I think it is a good idea to have the charge circuits tested to be sure.
Apr 23, 2012 | Fujitsu LifeBook N3410 Notebook
Laptop wont power up?
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 03, 2009 | Computers & Internet
Replaced the dc jack because it would not run on the charger. Still won't charge or run on charger. Is there a voltage controller on the motherboard, because the charger puts out 19.5 static volts a
Jun 03, 2009 | HP Pavilion ze5185 Notebook
Fujitsu AMILO Pro V2035 PC Notebook
If it's only 10 months old it is still within the manufacturers warranty, so do not touch or alter anything to do with the charger or battery, as even though the battery is seeming to be the fault, it is normally the motherboard charging point that is faulty or the motherboard not recognising the battery is connected.
May 02, 2007 | Fujitsu AMILO Pro V1000 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
