Question about Sharp Televison & Video
Trying to set up a new samsung le32a467
Trying to set up a new samsung le 32a467c1d plugged in uhf aerial coming up ''no signal'' however when plugging same aerial into my main lcd dtv is working fine
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
  • 7 Answers
SOURCE: Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
Posted on Oct 03, 2008
SOURCE: Can't tune in my Samsung DTV channels
WDDW
Posted on Nov 17, 2008
SOURCE: weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Posted on Nov 18, 2008
SOURCE: built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Posted on Dec 25, 2008
Wil my tv work with out remote
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.connecting the speaker wires of an RCA TV to an amplifier: The signal that is fed to the speakers is not designed to be fed to the line-level inputs of your amplifier. You'd need some kind of conversion and I can't tell you exactly what that would be.
Get some double-screened satellite cable and fit a female TV plug to it (or a male plug with an adapter). Connect it to RF Output 2 at the rear of your Digibox. Fit a TV plug to the other end and plug it into your TV.
Temporarily disconnect the aerial feed from the Digibox aerial socket. Switch the Digibox on to get a picture on your main TV. The Sky Digibox normally sends its signal out on UHF channel 68 so go to the second TV and tune it to 68 (or tune it till it finds the Sky picture).
Now plug the aerial cable back into the Digibox. If there is now interference on the Sky picture on the second TV (or on the terrestrial channels) your Sky signal on 68 is causing interference. Press [services] 401 [select]* and set the RF output to a different UHF channel number. You need to connect it via a Scart lead on your main TV in order to see the menu.
*In the new EPG (April 2009) it's [services] 001 [select]
Try each RF output channel number in turn (21 - 69) and retune the second TV until you get clean pictures on the terrestrial channels and the Sky channel. Also check the picture from the VCR (if connected).
This is just a brief overview. If you need a real in-depth explanation you should read the "Piping TV Around the House" Ebook by satcure.
Nov 22, 2011 | AOMNI Corporation Televison & Video
How to hook antenna to tv?
optimum reception of colour requires a good signal and will generally mean that an outdoor aerial must be used. the exact type and positioning of the aerial will depend upon your particular area your dealer or service personnel can best advise you on which aerial to use in your area. before connecting the aerial cable,turn off all main power switches. vhf or uhf it must first go to the media box and you will see the input aerial cable connect it there and the output go to the back of your tv that indicates aerial input terminal.
Oct 15, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Cant retune to pick up dvb samsung le 26r74bd
Hi return the TV with out the aerial connected and wait until it finishes then plug the aerial back in and try again. Let me know how you get on.
Apr 22, 2010 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
How to connect settop box to tv with no avs
You will have 2 UHF plugs on your set top box.. One for input (aerial) and 1 for output (TV). Connect your main aerial to set top box UHF input and connect an Output UHF lead from set top box to TV. Next switch on set top box and retune tv on a spare channel until you get set top box channels (good idea to switch on menu on set top box so you know you are tuned into set top signal )
Feb 12, 2010 | Philips Televison & Video
Technika 19in f/s telly in bedroom cannot get any stations with a portable ariel - can I get a different aerial instead of having to rewire the house!
One solution is to buy an hight gain aerial and a UHF amplifier booster box..but if you dont even receive poor quality signals then i think you will be struggling without relocating aerial into the loft or outside on a wal or roof. or wiring to a main aerial input via a matched splitter
Oct 17, 2009 | Televison & Video
I must be doing something wrong !! My Technika 22" LCD TV goes through the set up process and only picks up the BBC channels , Can anybody tell me how I can view any of the freeview channels ???. They dont...
Hi I am Vortash .. usually the problem is aerial the digital aerial is diffrent to the old UHF aerial and you will need to change it should you still be using it .. from what you say the set is working fine and you didnt do anything wrong .. it is just like unlike the old annalouge signal where you would get a picture even if it was poor .. digital systems are less forgiving of low signal and just blank the low signal channels out .. to check for sure if your not already , use a set top aerial.. and move it about to find the best signal if you get more channels problem found so update your aerial ( Or stand the kids in the corner holding the aerial ?LOL ) I hope this helps and that you will be on freeview soon .. oh and check with the ITA that your area has full Freeview transmissions .. there is a 24 hour call line .. on 0800-40 85 902 and they will give you all the information you will require hope this helps Regards Vortash
May 20, 2009 | Sony Televison & Video
No signal on teristeral but able to watch tv through sky
This could be down to several things so sorry if this is long winded but really needed more info from yourself...
Sky gets its signal from the dish mounted on your exterior wall.
your terrestrial signal comes from your terrestrial aerial be it external or internal.
If you do have an aerial cable coming into your property and it is connect to your television. Go into your TV MENU and set it away on Auto Tune if this does not come up with any channels. Try auto tune on your built in Digital tv ie DTV if it has this option...
If neither of these work then you need a new aerial or it needs to be re-aligned.
Personnally I would not bother with a Terrestrial Aerial You already have Sky installed so this will be fine for when the Whole of the UK goes digital. Dont be fobbed off by people telly you that you need a Digital aerial as your sky dish is already Digial anyway.
Hope this Helps
Little Dish Fitter
Apr 12, 2009 | Samsung 37 in. Flat-Panel LCD HDTV
Bush 2874ntxs aerial problem
i messed around with the remote, searched for my 5 channels and found them on uhf, stored and now i can look at my tv, thanks, gra.
Jul 04, 2008 | Bush 5693D 24" TV
Setup will not connect to uhf stations using rabbit ears antenna1
Signal is not strong enough. Use outdoor aerial for best results.
Aug 21, 2017 | Sharp 27U-F510 27" TV
Televison & Video Logo
73 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
