Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Will not drain
My washing machine will do the full cycle but when its meant to drain and spin its not draining and if i open the door water pours out,its driving me mad,ive got 3 children and need to fix this
  • 108 Answers
It sounds like the drainage may be blocked to prove this ;
1. Switch of the Washer
2. check youve switched off.
3. have a bucket handy.
4. Pull unit forward so you can access the pipes behind.
5. Locate the grey waste corrigated pipe connected to the waste plumbing. (Not the thin water pipe)
6. Remove corrigated (thicker) pipe and hold over the bucket.
5. switch unit back on. (Holding pipe over bucket)
6. Set the unit to final spin and start - this should empty the machine completely.
If the machine empties then your plumbing may need attention because the washer cannot push its waste water out through it.
You should get a full bucket load maybe more - so be ready to empty the bucket down the sink and reposition it.
If not then the drain pump motor may be faulty. This costs £19.99 + delviery from hotpoint - see : http://www.4hotpoint.co.uk/cgi-bin/search.pl?parts_search=s&model=wd63&part=pump. You will have to fit this yourself - or get a friend/engineer. I have never fitted one but anyone handy and safe with tools should be able to fit. I would guess no more than one hour to do.
However:
If you have warranty (machine is less than 1 year old) or paid for extended cover then call hotpoint to see if they can be booked in urgently...This should be free.
If you don't have warranty (your machine is older than 1 year) then its still worth calling Hotpoint - you will be charged £90 callout but parts are free for machines less than 5 years old + its warranted for 30days. This is what I recommend - especially if you have kids at home over easter!!! (then get the Extended Cover afterwards)
Call hotpoint service on 08704422510
Please don't forget to rate me
kind regards...
Posted on Mar 26, 2008
SOURCE:
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Frigidaire washer does not drain
Remove the drain hose from sink Unplug machine Safety 1st....put hose over bucket should gravity drain next take out the filter if its got one bottom /right hand side of machine clean...if not locate drain pump and remove blockage...kids sock maybe? Door may reset after water has been removed and unplugged .Good luck
Jun 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
Wash machine will not complete spinnging cycle & door will not unlock?HELP!!!!!!!!!!!!!!!!!!!!!!!!!
Hi.
Door does not unlock because there is water inside the machine.
Before unlocking you need to disconnect power. With power off remove trim at the base and access the drain pump filter. Open the housing and collect water. Also check the drain hose at the back.
The fault is usually either drain problem or defective door latch. I resumed here the full troubleshooting : If you have no spin there may be different reasons behind the problem. Before advancing to spin
Regards.
Ginko.
Mar 07, 2011 | Maytag High-Efficiency 2.4 cu. ft....
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Water will not drain cannot open door
The possible problems here are blockages or pump failure. Blockages are the more likely explanation but pumps can fail. If the washing machine will not empty the water out you may also not be able to open the door on some washing machines although these days it's much rarer to have a pneumatic lock on the door due to cost cutting (if a washing machine has a pneumatic door safety lock a rubber hose is connected to the door interlock from the pressure chamber bottle on the tub - water in the tub forces air up this tube and locks the door, which is released when the water is pumped out and the air pressure drops).
Some washing machines have a filter at the front of the machine that can be checked for blockages. Sometimes the filter is hidden behind a removable trim or panel at the base of the front panel. If your washing machine has a water pump filter and a filter drain hose you should be able to drain the water from the washing machine into a bowl without moving the washing machine. Open the pump filter flap and pull the small drain hose forward. Take the bung out and drain into a bowl. It's likely to be painstakingly slow but at least you don't have to try and pull out a heavy washing machine full of washing and water.
If your washing machine doesn't have a pump filter, or it has a pump filter but no draining hose then it's a bit trickier. To drain the washing machine, you will need to remove the drain hose from the drain pipe at the back of the washing machine, and lower it into a bowl or bucket. Many plumbers now plumb the drain hose into the U bend directly under the sink instead of a separate waste pipe at the back of the washer. If yours is connected directly to the u-bend, you can usually unscrew it easily. Remember though, that with the pipe disconnected from the U bend, any water poured down the sink will flood out into the cupboard until the hose is reconnected.
Once you have drained the water, you need to check for blockages in the pump by unscrewing the pump filter. If none is found, sometimes a blockage can occur in the plastic connector that the drain hose is connected to at the sink end (if connected this way)
Once you have the drain hose disconnected and lowered into a bowl or bucket the water should siphon out as long as the pipe is low enough. You are likely to get several bowls full of water from the washing machine. If little or no water comes out then it may be blocked by an item of clothing like a sock and it won't be possible to empty the machine this way or it is going to be a long process.
Once the last bit of water has drained out, the washing machine may now spin as the safety system for preventing a spin while water is in the machine will now recognize the water has gone and allow a spin. Keep the pipe low down and in the bowl or bucket and put the washing machine on a spin only program. Note, this last step is not strictly necessary as once drained, the door should open. However, you might prefer to try to spin a few more bowls of water out.
Clearly if you put more water into the machine it is likely to fail again until the fault is rectified but these instructions should at least get the clothes out.
Other possible obstructions could be inside the sump hose leading to the water pump. Many Hotpoint washing machines have a filter inside the sump hose which gets blocked. Finally, the pump itself can be faulty.
Dec 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Water is not draining
remove the drain motor knob in back or front side of the machine..there may be a some dust clean it it will work
Jun 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
Frigidaire Gallery washer is flooding the house
Try turning water faucets off. Does it still flood when done? Does your drain hose empty into stand pipe that is at least 30 inches from floor? Make sure drain hose does not go anymore than a few inches into pipe. If it is pushed too far in, unit can syphon water back into unit.
Nov 22, 2007 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
416 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
