Question about Sewing Machines
Needle up and down broken on my Janome
I have a Janome MX 3123 and the needle up and down feature just quit working today. Everything else works great, but this is one of my favorite features. Is there a way to fix this?
Thanks in advance.
    Genius:
  • 1,116 Answers
Take in for service.
Posted on May 01, 2010
The needle threader on my Janome 6260 quit working. The needle is inserted correctly.
Is the threader broken or just not meeting the needle eye? If broken, it can most likely be repaired.
If the threader is not meeting the needle eye, adjust the needle height so the threader meets the eye and intercept the thread. I have a 60's machine with a threader that needs the needle height manually adjusted because the needle does not stop in any particular place. Usually, if I raise the needle to its highest, the threader will work.
Oct 06, 2016 | Janome Sewing Machines
Needle up/down button doesn't work
Replacement button may still be available, it is really just a tiny push switch and can become faulty.
Call Janome dealer and discuss ordering one for you, or ask us
Contact Us at Bargain Box
Janome HQ is closed this week, so unable to ask them about availability, but Part Number is 753511004
Apr 05, 2014 | New Home MX-3123 Computerized Sewing...
Where is the indicator to move from one pattern to another on the New Home mx 3123 ? The red light is on behind pattern 1.... How do you move it? Thanks!
it is the big knob on the right hand side below the bigger wheel that moves the needle bar up and down. You have to turn it clockwise to move the indicator to the right all the way to # 13 for straight stitch. It will make a loud click with every move. Make sure the needle is raised up because it jumps back and forth as you move the dial. When you make a buttonhole using pattern 1, when one finishes you turn the dial to #2 then back to #1 to reset the program. I have one right in front of me if you have more questions. This is an AWESOME machine and should never wear out :o)
Jan 15, 2011 | New Home MX-3123 Computerized Sewing...
How do i make the needle stop in the down position instead of the up position? New Home MX3123
You can't - it is only designed to always stop in the up position, then you can manually push the "needle down" button to make the needle go down while you turn a corner. The next model up the 4263 had the "stop down" option. Sorry.
Oct 25, 2010 | New Home MX-3123 Computerized Sewing...
How do you fill the bobbin
there should be a bobbin winder on the top of the machine, that when you move it into position stops the needle from going up and down, but instead when you use the pedal it turns to wind the bobbin thread on
Aug 26, 2010 | Janome MyExcel 3123
The fabric keeps getting pulled down into the machine when trying to stitch. I've tried to change the needle, clean the lint and rethread the machine.
try these suggestions
1.make sure the needle is in the needle holder correctly
2.check to see if the needle is in backwards
3.make sure the thread is not slipping off the take-up lever
4.check to make sure the bobbin is not warped
5.check for lint in & around the bobbin case
6.check for loose thread in or around the bobbin case
Jul 31, 2010 | Janome MyExcel 3123
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
Janome machine going backwards instead of forwards. Goes forward if I hold the reverse button down.
sounds like a screw may have become missing to keep the reverse knob in its proper position so it is backwards inside the machine
Dec 13, 2009 | New Home MX-3123 Computerized Sewing...
My janome sewing machine isn't locking the thread
If u r new to using sewing machines please take some ones help who knows using any machine. You obviously are not fixing correctly. It should click in right place and the machine shd be able pull the thread before u begin stitching.
Oct 16, 2009 | Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
