Question about Maytag Neptune FAV6800AW Top Load Washer
Very loud at spin cycle then smoke - Maytag Neptune FAV6800AW Top Load Washer
  • 526 Answers
Hey KD,
Can you confirm the model number is it a FAV6800A or FAV9800A?
This is not good you may have seized Outer Tub bearings but let take one step at a time.
If you machine is the above I would need the first two digits of your serial number it will be 10 thru 17 here is where it is located on the above machines supported in this forum.
Hey KD,
We would first want to open the lid and see if you can Spin the Wash Basket CCW it should rotate CCW with very slight resistance.
I'll post a link the will help you remove the front cover and a link for the Service Manual and parts look up.
See the first part of this post to remove the front cover….. Clutch Fix
The Service Manual for reference. Sears Parts Direct for reference.
Rich
Posted on May 01, 2010
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
It made a loud noise during spin cycle and started smoking
Doesn't sound good does it?
Smoke could be a burned and shredded belt. Worse, the motor is burned out.
Loud noise? Depends on what it sounded like. Could be the concrete balance weight hitting the cabinet. Could be the belt hitting the cabinet when it snapped.
You need a repair man to diagnose.
Aug 24, 2015 | Washing Machines
GE front load washer model number WBVH6240HWW SERIAL NUMBER RM200099T spins freely by hand but started smoking and belt behind looks fine. What could be the problem. Before the smoke started when spin...
Hmm... Kind of difficult to say for sure. Does your inner spin basket wiggle up and down? If so, you've got a main bearing going. Also, put it in a spin cycle for a minute or so and then try smelling the windings on your main motor. If they smell burnt, you'll need to replace the main motor. Also, one last thought, check to see if your drain pump overheats. I say this because the drain pump is active during the spin cycle and a bad drain pump can sound extremely noisy and start overheating.
I hope this helps. Good luck!
Oct 19, 2014 | Washing Machines
Smoke coming from inside drum after spin cycle
The noise would possibly indicate that your drum bearings are on their way out, this would more than likely mean a new spider assembly, tripod in shape and houses the bearings through the drum, as well. They come in kits or bearing assembly alone for various prices, usually around 40 pounds for the kit but it would be a very difficult job if you are not familiar with this type of work, bearing extractor kits are best used but more cost, drum seals may also be needed.
Jan 23, 2014 | Hotpoint WMA35 Front Load Washer
Make loud noises on spin cycle and smoke when we open door
The loud noises seem to be a feature of newer front loading machines. We bought a Maytag and have had similar issues since day 1. We were told the bearings are the problem. They don't last and make major noise as they wear.
Oct 28, 2013 | Samsung WF316BAC 3.79 cu.ft High...
Is it worth trying to fix
wow, those bearings must of got really hot,, replacing the bearings is a very cheap job if you do yourself, if you think you can tackle doing them, go for it
Sep 12, 2013 | Fisher and Paykel Washing Machines
Washer started to smoke during spin cycle then a cracking noise began after that.
You may just have a defective drive belt. The motor itself will smoke under certain failing circumstances. Can you give me a model # ?
Jan 07, 2013 | Washing Machines
Amana dlw330 washer belt urned & broke again
Had the same problem on a machine I worked on. Changed the belt... was burnt and broken. Second time I replaced the belt, I ran it through all of the cycles and listened to it on SPIN cycle.. Although it's spinning.. it's making an extremely LOUD noise... It's the Spin bearing that is gone out. When a load is put in, and in spin cycle, the bearing is oveloaded..(being dry).. and putting extreme pressure on the motor and belt. When the drum reaches a point where the bearing just won't spin, the belt stops, and spins on the motor pulley, wearing it through.. (And smoking a great deal).. until it breaks.. again. I believe the top "Spin bearing" is about 75.00 or so.. and a BEAR to replace. Hope this helps
Feb 26, 2009 | Amana DLW330RA Top Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
