Question about Meade 8" LX90 LNT Schmidt Cassegrain Telescope with SmartFinder w/ FREE UPS
Power No power on my LX90. I tried different batteries - external as well as internal. [email protected]
  • 3 Answers
If you still have the red Led light on the scope's body, then...I ended up replacing the hand controller.
Tom Net
Posted on Apr 09, 2008
SOURCE:
Okay my sister had her tablet she turned it on and it froze at the go screen. So I pushed and held down. The power button and it turned off, and then I don't know why I pressed the reset button but it...
Do a factory reset. Remove all power including internal battery. Let the unit discharge completely. Plug into external power supply and try to start up. If it starts. shut down, put the external cord out , replace internal battery, and recharge for an hour. Now try a strat from the internal batter. If it fails, that s the problem.
Feb 03, 2015 | Tablets & eReaders
Why won't my nikon coolpix l810 turn on despite having new batteries?
It could be broken but it seems more likely that the batteries are faulty or not making proper contact or theres a fault with the power jack or battery wiring
Total failure with no attempt to come on is quite rare. I would try another set of different batteries and if that fails try an external power supply. If the external supply works then the problem could be that the external jack has lost the internal battery connection, or just plugging the external supply in and out might restore the connection.
May 13, 2014 | Nikon COOLPIX L810
Acer monitor wont exit power save mode. Ive tryed 2 different monitors. 1 the acer the other a dell and didnt work on both, but the dell works fine as long as its not that pc. I removed the motherboard...
Assuming that it is an "external" monitor, and not the built-in LCD screen in your notebook, you have to tell your computer which option you want:
* output only to internal screen
* output only to external monitor
* output to both internal & external.
Look for a BLUE-coloured 'FN' key on your keyboard, and a button that cycles through the above 3 settings. Push that button while HOLDING the 'FN' key down.
If your computer is set to "internal-only", then the external monitor will _stay_ in "power-save" mode, although the monitor will work fine if connected to some other "desktop" computer.
Apr 02, 2010 | Acer Aspire One PC Notebook
How to replace internal clock in lx90 8"ACF. Meade LX 90 8" ACF with UHTC
Probably just needs a new lithium coin battery - located behind front panel.
Feb 21, 2010 | Meade 8" LX90 LNT Schmidt Cassegrain...
S7000 finepix switches itself off when external power is plugged in
I am using Fuji Finepics 7000 for the last 4 years & took approx. 35,000 photos in Australia. Try not to plug in external power when camera is using internal batteries. Switch it off, plug in the external power cable & then switch it on. BYE [email protected]
Jan 18, 2010 | Fuji FinePix S7000 Digital Camera
Problem with alignment of Meade LX90 8" telescope
Start from scratch-
RESET the hand controller.
Calibrate motors using the same power source you will use outside.
Re-train the drives
Calibrate sensors on Polaris
Use either the 110 volt power cord, or buy a 12 volt power pack and the proper Meade 12 volt cable. (www.scopestuff.com carries the right 12 volt cable)
If your scope is NOT the LNT or GPS model you must level the tripod before you align. Go to home depot and buy the $3 small plastic two way bubble level, or the bulls-eye style bubble level.
Further trouble, I suggest going to the LX90 Yahoo group forum, and asking questions there.
Good Luck
Aug 30, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
IMac won't recognize my external speakers
I had the same problem..... turns out that there is a specific order that you need to plug them in. Disconnect your speakers from usb and from power. Then plug in the Power first. Then plug in the usb connection. They should show up in your sound control panel now.
Jun 24, 2009 | Apple MacBook Pro Laptop Computer with...
No power to the autostar
You may want to try a new cable to the Autostar.
Nov 02, 2008 | Meade LX90GPS: 10" LX90 GPS Telescope
LX6 Hand controller....error message
If the hand controller on the LX6 has stopped working you have a problem since meade does not support this very old telescope. My only suggestion would be to place an ad on www.astromart.com looking for a new hand controller.
If the error message indicates a "motor fault" make sure you have a good power supply and or fresh batteries-- as low voltage will cause a motor fault error.
Later you said it was an LX90 LNT-- ?? so which scope do you actually own???
Apr 25, 2008 | Meade 8" LX90 LNT Schmidt Cassegrain...
Lx 90 gps
I have an older one, without electronics just a tracking motor, and that one has a positive polarity tip.
Mar 29, 2008 | Meade 8" LX90 LNT Schmidt Cassegrain...
Meade 8" LX90 LNT Schmidt Cassegrain Telescope with SmartFinder w/ FREE UPS Logo
90 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Gep Pep
Ekse
Are you a Meade Optic Expert? Answer questions, earn points and help others
