Question about Garden
Blower will not run up past idle and runs rich with oil coming out of exhaust. I got a kit to rebuild the carburetor but I don't know where the small screen goes and it still doesn't run when I re-assembled it. Any ideas?
  • 63 Answers
The blower is old, and the piston rings are worn. you need new rings, and possibly a new bore, or i'd just purchase a new blower.
Posted on Jun 28, 2010
Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
  • Replace fuel filter, it's in the gas tank
  • Check and clean the Spark Arrestor screen at muffler, when they plug up, it's a major restriction to exhaust gas flow
  • And check and adjust High/Low screws at carburetor, video attached.
  • And clean or install rebuild kit for carburetor
Good luck...
One more...
May 30, 2015 | Troy-Bilt Garden
Why does my redmax ebz8500 blower start fine and run fine for a few minutes and then bog down and rev back up? The carburetor, air filter, fuel filter, fuel lines and spark plug are all brand new.
Based on the majority of small 2-cycle engines out there, I would suggest rebuilding the carburetor. It's easy to do and kits are usually $10 to $12. Remove the air filter and retrieve the number printed on the carburetor. Then, look on eBay or visit a local small engine repair shop for parts. Remarkably, there are a very small number of carburetors used on a majority of different brands with 2-stroke engines. So, if you buy a kit based on the carburetor number, don't worry if it's not directly referenced to your particular brand of blower.
Sometimes, you can get positive results by partially disassembling a carburetor and cleaning it with spray carburetor cleaner from Walmart or Auto Parts Supply store. But, if you're going to that much trouble, you might as well replace parts as you go. Over time, rubber seals dry out and plastic reed valves leak by. Recently, my chain saw was acting up. I replaced hoses, filters, spark plug, etc. Even flushed the carburetor with cleaner. Nothing helped. But, once the carburetor was rebuilt, it purred like a kitten. I've experienced the same thing with weed-eaters and other engines, too. Fortunately, 2-cycle engines are not complex and usually easy to fix. Good luck!
May 05, 2014 | Garden
I can't get my blower to accelerate. It will only idol on full choke. If you pull trigger it bogs down. I replaced the fuel line and sprayed carb out.
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the Fuel Tank
  • Spark Plug
  • Spark Arrestor - at muffler
  • Carburetor - May need a rebuild kit
Watch this as well...
and...
Oct 18, 2013 | Stihl Bg 55
1985 Ford F150 302,5.0 Smoking running Rich and idling high and low
first of all u need to determine what color of smoke it is and is it coming out of the exhaust pipe. black smoke means excessive gas burning ...blue smoke means burning oil ...white smoke if seen in warm weather conditions means coolant leak into cylinder heads... but as running rich and high low idle might have a vacuum leak or carburetor need new base gasket or rebuilt ... good luck
Oct 13, 2013 | Cars & Trucks
I have a 1993 pick up hardbody' a lot of black smoke coming out and idle is rough..any suggestions on what may be the problem?
With the black smoke, it sounds like it's running rich (too much gas going into the motor). Remove a spark plug and take a look at it- if it's all black and sooty, then yes, your motor's running too rich and you need to lean out the fuel mixture. I'm not positive, but that truck probably has a carburetor and you could do the adjustment yourself, with a little help from a shop manual. If it's fuel injected, you'll want to take it to a shop or a friend that knows what they're doing to get it adjusted right again.
If the spark plug has little tiny clumps of stuff stuck to it you're burning oil, and that's a bigger problem. An oil leak means a fairly major engine rebuild is in store for you. If it is burning oil, I'd just drive it like it is until it eventually conks out or something else goes wrong on it. Unless, of course, the truck is special to you and worth investing in an engine rebuild...
Jan 26, 2013 | 1995 Nissan Pickup
How to tune a b210 caburatorI manage get the idle tuning perfect next how to tune the rune up(when in running it put out blak smoke)
Something internal in the carburetor is wrong, maybe the accelerator pump seal or gasket is bad. Think you will have to put a rebuild kit in the carb. There's no outside adjustment for it being way too rich.
Jan 10, 2013 | Nissan Pickup Cars & Trucks
Pb-413h echo back pack blower bogs down when throttle is applied , idles fine .
This is usually caused by one of two problems. First, the exhaust may be plugged. Pull the screws out of the small screen in the exhaust and wire brush the screen. Reinstall and try again. I had one where some bee's built a nest in the exhaust, no tcommon though.
Second, teh fuel pump in the carburetor may be on its way out. It may provide enough fuel to run at idle but not at high speed. You may need a carburetor rebuild.
Feb 15, 2011 | Garden
My mcculloch air blower will start but dies right away?
If you have difficulty with starting the 2-cycle blower (especially if it has been sitting for 6 months or more:
It is most likely you will need to service the carburetor. Today's modern fuels will, over time, gum up the carburetors and small passage-ways within the carburetor making the carburetor ineffective. A carburetor rebuild kit can be a DIY project.
You can also remove the exhaust or muffler to visually insure that the small screen (if applicable on your actual model) is clear of carbon build-up. Clean/replace and retry.
Before you rebuild your carburetor or remove the exhaust, try the simple things below:
1. Air Filter maintenance. Your air filter needs to be reasonably clear. You can clean with water/soap, insure it is dry and lightly oil and replace.
2. Replace your pre-mix fuel or determine that is no older than 2 months old.
Sep 24, 2010 | McCulloch Garden
My whipper snipper is petrol 2 stroke and does not run properly. It is hard to start and then when it does seems to lose power and stop. What do I need to do to fix the problem??
May have a screen in the exhaust that has plugged up with carbon. You can take the screen out and it will run properly if that is the problem. Otherwise, it could need a carburetor cleaning. If you are going to rebuild the carburetor, you probably should get a carburetor rebuild kit from a small engine repair center for your particular model.
Dec 29, 2009 | Ryobi Garden
Homelite 2 cycle backpack leafblower won't run.
yea check the gas lines and throttle cables for strech, probably need replacing or tightening.
Jan 03, 2009 | Homelite Consumer Products Backpack...
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
