Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
Water dispenser working, but ice maker not working
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fjkfdf
Posted on Sep 30, 2010
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
mine did same thing. What is happening is the Water Line in the freezer door is freezing.
SOLUTION. Leave the freezer door open and turn off the freezer for a night. Be sure to dump out all of your ice cubes too.
In the morning it will work like new. To prevent it from happening again, open the FRIDGE door and use the electronic controls to raise the temperature of the freezer. You had it too cold before...thats why your water line froze in the first place.
Posted on May 02, 2008
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
The power was off at my huose for 12 hours. When I removed the ice bucket I saw that water condensated and was now frozen around the shaft of the ice dispenser moter. The ice was prevent edthe motor shaft from turning.. I used a pair of needle nose pliers to loosen the 2 mouting bolts of the ice dispense motor approx 1/4 turn and all is well.
My wife thinks it's a miracle and that's all that matters!!!
Posted on Sep 15, 2008
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
  • 272 Answers
SOURCE: Water dispenser no longer dispenses water. Ice maker still works
Has it stopped completely or just slowed to a trickle. If a trickle you need to replace the filter. If stopped either the feed line to the fridge has been pinched/shut off or the internal line has frozen, or the valve is no longer functional.
Posted on May 25, 2009
Samsung side by side ice maker not working
You have 2 separate valves, 1 for the water dispenser and 1 for the ice maker. (otherwise your ice maker would overflow every time you got water from the dispenser and your dispenser would flow every time the ice maker went to refill.) They are fed from the same tubing.
The cube/crushed ice motor is completely separate from the ice maker itself and should have absolutely no bearing on the water flow.
You have narrowed down the problem quite nicely to the ice maker water valve. There is one more thing to check though, the connector. There should be a multi-contact connector from the ice maker to the back wall of the freezer, usually 6-9 wires. Pull that apart and check the cord side (ice maker side) for any corrosion. BE CAREFUL NOT TO TOUCH THE OTHER SIDE AS THERE IS LIVE 110V!!! If you don't see any corrosion, still try try disconnecting and reconnecting 5-10 times and see if that solves your problem. If you see corrosion, unplug the refrigerator before working on the back wall part of the connector. [This connector besides powering the ice maker also allows the ice maker to control the water valve which can't be inside the freezer]
Sep 03, 2016 | Samsung Refrigerators
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice maker will not make ice, water dispenser is working
heatman101
oypyiooiyp
May 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
422 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
