Question about Yamaha RX-V392 Receiver
I plugged in the CD Player Out into the Phono In jack on the back of my Receiver Yamaha RX V382 and turned up the volume to 1/3 at what point I heard a bang out from one of my loudspeakers. From that moment on, turning of the Volume button louder would result in a complete power off of the Receiver (at approx 20-25% of the button turn up). I unplugged the unit. I checked the Impedance position switch on the back both in the 6 and 8 ohm positions), disconnected one by one the loudspeakers attached but nothing worked. Whenever I start the unit in Tuner, or CD mode the volume goes up to a point, then some relay clicks inside and the unit powers itself off. Is there any way to reset it, or have I damaged the amplifier unit? Thank you
  • Yamaha Master
  • 5,190 Answers
The first thing I can say is that the CD player should not have been connected to the phono jacks as this is for a record player, therefore you amplified the CD player output greater than what it should have been!
Next a damaged loudspeaker could cause problems to the amp. A simple test is to connect each speaker (disconected from the amp) for a second to 1.5 volt battery. You should hear a pop sound from each of the speakers and make certian that each unit inside the speaker pops too. If the speakers are 8 ohm set that switch at 8. Never connect 6 ohm speakers with it at 8! Check the cables are good and are not shorting out.
If I was you I would have a look inside the unit and have a look at the semi-conductors on the heat sink. You might see damage! If they are transistors you can put an ohm meter on the transistor terminals (B,C,E) (amp power off). If any act like you have just touch the test probes together, you have a shorted part and the reason it shuts down.
Posted on May 01, 2010
Testimonial: "Thank you, it helped me continue try with a different set of loudspeakers (8Ohm)on the jacks for the second set of speakers out (B). It worked fine. Then I replugged the original set of speakers (6ohm) on A and made sure + line out goes into + in on the speakers. It worked again. However, before this incident I could use speakers of 6ohm on A and 8ohm on B at the same time. I am not sure what was the problem and if there is stil some form of intermittent fault or damage..."
How do I connect my Yamaha RX-V733 to cd player?
Assuming the CD player has a standard 3.5mm headphone jack, get a 3.5mm to RCA audio connector. Put the 3.5mm plug into the headphone jack at the back of your CD player (or audio out if that's what it's labeled) and attach the white end of the RCA jack to the white connector in the Phono at the back of your Yamaha RX-V33 and the red end to the red RCA connector just below it in the same Phono area.
Switch the Yamaha to "Phono" and start the CD player. You should hear things now.
Feb 21, 2017 | Yamaha Audio Players & Recorders
How do I connect an mp3 player to a receiver?
Simplest way: headphone jack cable to 2x phono/RCA and connect to one of the audio inputs.
Better quality: Good MP3 player dock (if available) and then connect either digital out or analogue stereo out to the receiver.
Sep 10, 2014 | Yamaha RX-460/360/R-85 SERVICE MANUAL...
How to connect my JBL JRX 115 speaker to my Yamaha RX V673 receiver
You would use a standard banana plug to either a 1/4 phono or speakon plug. The JBL JRX 115 has both on the back. All the outputs on the Yamaha RX V673 have banana plugs. The channel you plug into would be up to you, there are many choices and they are listed on the back of the unit.
Dec 03, 2013 | JBL Audio Players & Recorders
Want to know if it is possible to hear a record player through the AUX plug out? since my Yamaha RX-V396 receiver doesn't have a phono plug out
hi,
Only you can hear the record player through the aux of your amp if the record player comes with built in phono preamp. If not you need a phono preamp between the record player and amp or an amp which have a phono input. Phono preamp is available in the open market.
ok
May 22, 2011 | Yamaha RX-V396 Receiver
Trying to hook up a wii game to the rear of the recevier need to know which jacks to use
Actually, most will work. AUX IN, LINE IN, or TUNER in will all accept the "line level" output of the Wii. Just pick one of those, start with the volume DOWN on the amp and fire it up. Slowly increase volume but if nothing is heard in the first 1/4 turn, you've probably got something hooked up wrong. Back it down again and try another input or check connections.
Dec 28, 2010 | Yamaha RX-V459 Receiver
Can I use an Ipod Dock with a Yamaha RX V490 receiver?
No, but you could still access the audio directly from the iPod...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to an amp or receiver. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
http://www.retrevo.com/support/Yamaha-RX-V490-Receivers-manual/id/319ci975/t/2/
Dec 01, 2010 | Yamaha RX-V490 Receiver
Can an ipod or mp3 player be hooked to a Yamaha RX-V596, using an auxliary cord
Typically you can find an adapter / cord that contains a 3.5mm headphone plug on one end and a pair of RCA plugs on the other. These RCA plugs should be able to be plugged into any available input on a receiver that isn't a PHONO input. These cables can typically be found online at various different places. Not to promote one site over another, but I have had good luck finding random cables like these at Cableswholesale.com and allelectronics.com. Hope this solves your problem.
Thanks,
Ben
Mar 29, 2010 | Yamaha RX-V596 Receiver
When the volume is raised to a certain point -- not high at all -- the receiver turns off, whether on cd, phono, fm, or tv.
Disconnect all speaker wires at the receiver then turn it back on and turn up the volume. If it still cuts out, it needs serviced. If it stays on, reconnect one speaker at a time and test. once you find the wire that causes it to shut down, disconnect that wire at the speaker and test again. If it stays on, meter the speaker for a short. If your not sure how to do that, take the speaker to any electronics shop and they will usually test them for free. If you need further help with this issue, post a comment and I can help.
Nov 06, 2009 | Yamaha RX-596 Receiver
Yamaha RX-V861 Low frequency "flutter" after turning on
How close to your video monitor is this rxr? It is not shielded well as far as sync circuits in your TV are concerned. Refer to manual...accordianman
Apr 03, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V392 Receiver Logo
98 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
