Question about InFocus ScreenPlay 4805 Multimedia Projector
How much does a light tunnel repair cost?
I had the same light tunnel symtoms as a previous post. It resulted in what appears to be a burned out bulb (short fuzzy crackly sound followed by darkness and a flashing red light on the top of the projector). This would be the second premature bulb replacement if I do it.
How expensive is a light tunnel repair?
Where can I get that repair done?
Is it more cost effective to buy a new projector?
Is there a comparable projector that is not plagued with this issue?
Thanks.
  • Anonymous Apr 04, 2008
    darkenes in te screen right side
  • 138 Answers
Infocus SP4805 light tunnel is not expensive, only cost USD79 with shipping.
it is better to buy a new light tunnel than buy a parts machine.
Posted on Mar 28, 2012
  • 563 Answers
Hi there
The light tunnel is not a expensive part to have replaced and it is better to do it than to keep on buying new lamps.
You can easily find your nearest Authorised Service Dept online.
Tip : Don't let just any monkey do this type of work on your unit , rather pay a bit more with the authorised agents.
Posted on Mar 27, 2008
  • 26 Answers
A failed light tunnel will NOT cause anything else to fail. Your lamp failure is completely unrelated. The only thing a light tunnel failure will cause is shadowing of the image on one side. It is a 4-sided mirrored tunnel, nothing more.
Posted on Apr 17, 2008
  • sheridan1952 Apr 18, 2008
    Infocus has discontinued parts for a number of their projectors,
    including the X series. You options at this point are to either
    attempt a repair to the light tunnel yourself or replace the projector.
Left hand side of image appears darker than rest of image as if a shadow is caused from somewhere. Unsure if this is a lamp problem or a camera problem
If it looks like a dark orange/brown band, its likely to be a Light Tunnel Failure. The Tunnel can be fixed thru the manufacturer, but it will cost plenty. You can also do it yourself.
For additional info, go to www.avsforum.com and search for "4805 Light Tunnel" and you will see threads about the problem...as well as DIY repairs.
I also posted a DIY replacement option since new Tunnels are virtually non-existent:
www.avsforum.com/avs-vb/showthread.php?t=1304694
Dec 24, 2010 | InFocus ScreenPlay 4805 Multimedia...
Tip
Infocus 4805 Light Tunnel DIY Replacement Option
About a year ago my light tunnel failed and I was able to fix it thanks to info on the net. Then about a month ago I decided to try to finally replace my Light Tunnel. Mainly because replacement parts are discontinued and manufacturer repair is way too expensive. In the process of failing, I was able to find a great low cost solution that's pretty easy to fabricate. My post is here:
If you have never opened your Projector go here:
http://www.avsforum.com/avs-vb/showthread.php?t=556431
It's regarding Dust Blobs, but it has pics to show how to disassemble the unit.
So as for the Tunnel and getting to it...here is a thread for a different model PJ, but the layout is very similar:
http://www.avsforum.com/avs-vb/showthread.php?t=618877
Hope this post is helpful to you :)
on Jan 07, 2011 | InFocus ScreenPlay 4805 Multimedia...
Half of the screen is dark. Tried a new bulb wilth no effect
Sounds like Light Tunnel Failure. Very common. Biggest problem is that a replacement part is almost non-existent and a manufacturer repair is expensive.
You can get further details on the problem at www.avsforum.com. Just search for "4805 Light Tunnel" and you will find threads about DIY repairs.
I also recently posted a DIY Replacement thread for anyone willing to make their own tunnel:
Nov 24, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have an infocus X2 projector that has a shadow on one side of the image. After reading other posts, this appears to be indicative of a light tunnel collapse. Is this problem repairable in an X2 and if so...
the light tunnel has collapsed and needs to be replaced. it's pretty simple to repair. there are directions on the "tips" part of my profile. so, you can get the part from an infocus service center and do it yourself or send it in to them for repair. either way, try www.avsolutionsny.com. they're really good.
Jan 29, 2010 | InFocus Office Equipment & Supplies
My Hitachi 60VG825 projection TV is 3 years old. For the past several months the screen has been turning blue around the outer edges & this past week a large yellowish green spot the size of a...
Sounds like Calibration is needed on the projection internals. Your TV uses a rear-projection system and the problem is either in the imaging LCD Unit or the light filter. I see in a previous thread you have changed the bulb. You can invest in a voltage regulator to keep the hardware in factory condition.
Also you can burn a DVD of a stuck pixel remedy video and run it on the screen with full brightness and full contrast. This is used for plasma burns and stuck pixels on conventional Flat panel TVs but can repair color issues with projection systems. This therapy is focused on the imaging unit between the projector and the main drop of your tv.
please feel free to post a more in-depth description or any changes
Nov 06, 2009 | Hitachi 60VG825 60 in. LCD Television
I need a new light tunnel for my infocus X2
Was actually looking up a different problem with an X2 and came across this thread.
I do electronic repair, and often do repair on projectors with this light tunnel problem. Probably 3 a week!
I came up with a solution about a year ago. It's a tunnel peice made of highly resilient carbon fiber, lined inside with extremely reflective mirrored stainless steel.
A company here in St Louis builds them for me and I go through quite a few!
If anyone is interested, feel free to email me at mhale@ahvio.com. I charge $50 per replacement tunnel (They are pretty expensive to make). Plus $10 for shipping to anyone in the US, unless you want to come by and pick it up.
I can include a extremely easy guide to install (Its VERY easy!)
These carbon fiber replacement tubes are a solid peice, unlike the factory that is just glued together mirrors :/ They are morons! haha
I've been using this replacement tubes for about a year now and installed well over 50, so I swear by them! Very resilient to heat, and very resilient to someone installing it that isn't very careful. It's almost impossible to break!
Also sale homemade LED super high flux projector bulbs for the X1, X2, and X3. May be able to build a bulb for a different brand, depending on what the current bulb is like.
These LED bulbs have a life of 40,000+ hrs and use very little power, and produce VERY LITTLE HEAT! Cheaper to build than the factory ones, at about $175 for a complete bulb with assembly. Have about the same ANSI output as the standard bulbs, I actually think it's a little more than the rated (like 50 more lumens or so~)
If interested in either, feel free to hit me up! Willing to send parts, or can do install myself.
Mar 01, 2009 | InFocus ScreenPlay 4805 Multimedia...
Power Failure, How serious a problem and cost?
Hi there
You will either be replacing the Main Power Board or the Ballast Board ( Lamp's powersupply ) The symtoms you described sounds like a faulty Ballast.
Both of the above parts are fairly cheap to replace.
Mar 25, 2008 | Toshiba TDP-T30U Multimedia Projector
Infocus x3 video problem
Sounds like it could be the mirror tunnel. There is a very small mirror tunnel behind the color wheel (looks like a long prism) that can often fail as it is very fragile. This tunnel concentrates and channels the light to the DLP chip and if it collapses it can cause the very issue you describe.
Feb 18, 2008 | InFocus X1 Multimedia Projector
Samsung 7181
This is a problem we are seeing quite a few. The problem is, you have a defective Lite-Tunnel. This can be repaired two ways. (1) The Cheap way. Replacing the Lite-Tunnel. This is somewhat complicated. You must take the engine apart to change the tunnel. After changing the Lite-tunnel it must be aligned. (2) The expensive way. Changing the complete Lite engine. This is less complicated, but cost a lot more. Lite engine Part Number BP96-00822J . Average cost $1300
Best regards
CircuitCity
Dec 07, 2007 | Samsung HL-R6167W 61" HDTV
Small bluish, black triangle at far right corner
This is the same problem as other posts have mentioned about the right side of the screen having a bluish-balck stripe down the side of the screen. Here's what's happening. There's a small light tunnel which has 4 very small mirrors located just behind the color wheel. The lamp shines light through the color wheel as it turns and the light goes through this small tunnel and is then relected off several mirrors before it is projected through the lens and onto the screen. Optoma apparently did not use a very good heat resistant expoxy glue when they assembled these mirrors and over time the mirrors drop down causing a shadow effect on the screen. It can be repaired without paying some repair shop a small fortune. Previous posts have a solution from another contributer whihc includes photos. I had to repair mine and it's worked fine since I used a decent expoxy to hold the mirrors.
Sep 28, 2007 | Optoma RD65 65" Rear Projection HDTV
InFocus ScreenPlay 4805 Multimedia Projector Logo
957 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
