1. evertime there is a message the phone beeps, need to get rid of the beep. can you turn off the beeping when there is a message? i use the phone more as an answering machine 80% of the time.
2. how can i set up to retrieve my messages by way of my cell phone or another land line away from my office.
get these two areas covered and i am good to go. thank mike [email protected]
Many of the telephones have a built in answering machine. The beeps are to let you know you have a message you have not picked up yet. This to help you not miss messages. Check your owners manual to see if you can turn off or mute the message warning tone.
It may have reached the number of cycles to trigger a delime warning. Either follow the procedure in your operator manual to delime, or go into the control board settings and either change or turn off the delime timer
The beeps are telling you that you have unheard messages on the voicemail system provided by your telephone company. This system records messages when people call while you're already on the phone. To get rid of the beeps you need to listen to the messages. Please contact your telephone company for instructions on accessing your voicemail system.
Dial Pad and Button Beeps Digital telephones can emit a “beep” sound whenever a dial pad or feature button is pressed. The “beeps” are On by default. Follow these steps to turn the “beeps” On or Off on 3000-series DKTs. 1. Press 3+6+9+Hold(simultaneously). 2. Press 0. 3. Press Feature Button 1 (FB1) to toggle On/Off. FB1, LED On: buttons beep. FB1, LED Off: buttons do not beep. 4. Press hold to set the option. 5. You must also go off-hook, then on-hook to exit the program mode.
There can be several reasons for this beep:
1. The phone needs a good charge before using again.
2. The phone was default programmed to beep when not on the base.
3. There is a message to be retrieved which has not been located and looked at yet.
4. Another set has left a message and needs retrieval.
These are a few.
I hope this helps, let me know
Your manual will tell you about this on page 4.
I had the same problem.
Here is the solution that I received from Motorola tech support:
1.Delete all messages
2. Unplug the power and re-apply power
3. Quickly press and release << (previous message) and >> (next message) buttons together while the "Press review to receive setup instructions" message is playing.
The display will change from a segment scanning clockwise to anti-clockwise
4. Quickly press and release the On/Off button before the "Press review to receive setup instructions" ends. The display will change to a square scanning clockwise.
Note, this goes by quickly. I had to repeat steps 1-4 a couple of times before I got it right.
5. Press and release the delete button. The unit will emit a beep.
6. Press and release the on/off button. The unit will emit another beep and annouce "Press review to receive setup instructions"
Done!
Here is a link to a similar model:
http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf
Here is what it says:
TONE REMOTE OPERATION
Remote Security Code
To access answering functions from an outside line, you
will need to enter the three digit security code located
on the bottom of your unit. Write this number on the
Remote Access Card, which you can keep in your wallet.
Remote Turn On
If you forget to turn on your unit:
1. Call your unit from a touch-tone phone.
2. Wait 12-14 rings until the machine answers.
3. The FA970 will automatically answer by playing your
greeting. You may hang up the phone, and subsequent
calls will be answered.
Remote Message Playback
1. Call your unit from a touch-tone telephone.
2. After your FA970 answers, it plays the outgoing
greeting and beeps once. Dial your three digit security
code within 20 seconds after the beep, pressing and
holding each digit for 1-2 seconds. Allow a 2 seconds
interval between each digit.
3. Your FA970 will sound one beep to indicate the code
was entered correctly. (If there are no beeps, enter
your code again.)
4. You can press the following buttons on your keypad:
Option Press
Playback Mailbox 1 Messages (1)
Playback Mailbox 2 Messages (2)
Record Memo Message (3)
Record New Greeting (8)
Turn Off Answer Mode (9)
If you press ?1? or ?2? (to playback messages), you have
the follow options:
Option Press
Erase Current Message (0)
Repeat Current Message (4)
Repeat Previous Message (4) repeatedly
Stop Message Playback (5)
Skip to Next Message (6)
To SAVE messages, hang up the telephone.
Note: Your FA970 will sound a series of beeps if there
are no messages.
Remote Record New Greeting
If you press 8 (to record new greeting):
1. When you hear a beep, begin recording your new
greeting (up to 30 seconds).
2. When you have finished recording your new greeting,
press (5). The unit will beep, and the new greeting
will playback to you.
3. Hang up the telephone.
Remote Record Memo
If you press 3 (to record memo message):
1. Within three seconds of pressing ?3?, press ?1? or ?2?
to select Mailbox 1 or Mailbox 2. Otherwise, the memo
will be recorded in Mailbox 1.
2. When you hear a beep, begin recording your memo
(up to 60 seconds).
3. When you have finished recording your memo
message, press (5).
4. The corresponding Mailbox message count will be
increased by one.
To Retrieve Messages when Recording
Memory is Full
1. When the message capacity is full, the unit will sound
3 beeps after answering the phone.
2. Within 20 seconds after the 3 beeps, dial your 3 digit
security code.
