Question about Vacuums
No water going through my hoover F5857 - Vacuums
  • 537 Answers
Sounds like a clog somewhere. I would check the clean water resorvoir as well as the hose inlets to make sure there is not a foreign object plugging it.
Posted on Mar 25, 2008
2 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: I need a manual for my Hoover F5857-900 steamvac.
I tried hoover.com, none came up for this model.
We're sorry, we were not able to find any models when searching with "f5857-900". Please check the model number, and if you are still not able to find any results, contact our customer service department at 1.330.499.9499.
Posted on May 22, 2008
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
I need a manual for model number F5853-900
HI There,
Unfortunately I couldn't find a manual for the F5853 specifically, but I did look up comparable models to yours, and the F5857 is nearly identical to yours.
Here's a link to that manual on Hoover's website:
http://www.hoover.com/pdfs/manuals/F5857955.pdf
If you have a question on how to do something in particular, please don't hesitate to ask me, I'm always more then happy to help.
If this was helpful, please be so kind and rate the repair, or leave feedback for me.
Thanks again,
Chris Jones
GoVacuum.com
May 14, 2010 | Vacuums
Hoover Steamvac Deep Cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40578&thid=661545
Hoover SteamVac Deep Cleaner
Posted by Alex987 on Jun 10, 2008
I can't seem to figure out how to use it =(
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5807 SteamVac Wet/Dry Vacuum. Well, there are 2 tanks, one is the water solution tank that is on top and the other is the water recovery tank of which is on the bottom. You use the trigger assm to release the water and the Hoover SteamVac works the best on the pull back. You can spry the water going forward but pull it back very slowly and let the brushes do the scrubbing for you and the dirty water pickup. There is a ball in the dirty water pup tank that will rise to the top and stop the water from coming in, @ that point you need to empty and rinse out the recovery tank and re-install. If you run out of solution the top tank cap or cover is the measuring cup to determine the amount of solution – usually it is one cap full and extremely hot water, there is a switch for the carpet and the upholstery, if the handle is in the released position then the brushes down below should be moving – just look in the brushes window and see if they are moving – if the handle is in the upright position then you can remove the attachment hose and then use the attachment and the revolving brushes will stop. I hope this will help you in working with the Hoover SteamVac. If not contact the Hoover Co and get an owner’s manual and give them the model # and serial #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
May 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Need help!!!!!
Need help!!!!!
Hoover F7425-900 SteamVac V2 Widepath Upright
I read the manual and tried my new Hoover, the brushes spin, but the waters not going to the bottom tank, what does that mean and what can i do?
You could have a bad water release valve on your water tank of which holds the water, the trigger assm might not be connected, bent or broken. Check the trouble shooting owners manual --- also there are hoses that could be crimped or bent, or clogged or not connected, but it is my guess it is the water release valve. Try to back track the water from the holding tank and test all the valves on the system and you might find the problem by the process of elimination. Feel free to contact you local vacuum cleaner dealer in the yellow pages or contact the Hoover Co @ the information listed below:
8 a.m. - 7 p.m. EST
Don – The Vac Man
Apr 22, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Does not pick up water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=529140
Posted by Dreams642 on Apr 20, 2008
I have had my Hoover Floormate for years. It has always worked great but the last few times I used it the amount of water left is tremendous and the container for dirty water was not full at all. I looked at it and the hose going up from the bottom thru the handle is broken how do I fix this.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Apr 20, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
102 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
