Question about Sony PlayStation® 3 (60 GB) Console
I turn it on but then it goes from green to red
One minute I'm playing online then the next minute it shuts off. So I try to turn it back on but it doesn't turn on all I see is the red light blinking
  • 186 Answers
Your on the wrong settng look at run time maybe need;s to be adjusted
Posted on May 01, 2010
I was playing Cod4 online, when it froze for a second, red light came on the console, and the console shut down. Now when i try to start up again, the fan comes on for a second, along with the normal green...
Check ur console first, then test the hard drive, then unplug the console from the wall for about half an hour and then plug it back in. The next step you can do to fix red light of death is to see if you still have a valid warranty for your gaming console and then Go online to expert sites which will show you some online programs that will fix PS3 red light blinking in just an hour better u download repair guide
click here to download repair guide
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
It quits projecting, the green light goes off and the red light of the bulb goes on. I've disconnected everything and reconnected, turn it on and it works for about two minutes and shuts off projector,...
Have you tried cleaning the fliters on the back of the unit? It's easy to do. Pull them out, and blow them clean. Also, is the projector well ventilated - mine overheats sometimes and shuts off. Otherwise, sounds like he bulb to me.
Oct 25, 2010 | InFocus Office Equipment & Supplies
Ps3 isnt working. was playing cod 5 online it just shut off. when i try to turn it on the light goes green. then orange, then it bleeps red
Yes this is the common red light problem and is caused by overheating on the main chips. Use a good repair guide or send it in and get it fixed.
Aug 24, 2010 | Sony Playstation 3 (PS3) Console
I turn my unit on and it turns off after a few seconds
After about 10 minutes of play time the power light goes from green to red and the system shuts down.
Jul 12, 2010 | Denon DRA-397
I was playing online and the computer shut down.it wont turn on now.The red light turns green but then goes back to red after 2 seconds.any ideas?
Most of the times, you're going to find that this is due to over heating. If you've been playing for a while, shut down your Playstation, and let it sit for about 1 hour. It's best if the room is cooled off as well.If the room is hot, you may want to put a fan blowing toward it, or turn up your Air Conditioning.Check the back of your unit, and make sure that all of the cables are plugged in. What you're going to want to do is take out each one, and blow the inside of the ports with compressed air.
To play it safe, take out the Playstation's hard drive, and place it back in.Once the 1 hour is up, and the Playstation hasn't been running, turn it back on, and see if everything is working. If it is, you're good to go! If it isn't, you may want to consult with Sony.
Thank you!!
May 18, 2010 | Sony Playstation 3 (PS3) Console
60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
I was playing online when the console shut down and the light on the front started blinking red. when i try to turn the console on the green light comes on and then turns yellow and then goes back to...
This could be any of a number of problems try these solutions one of which may work. If they all fail to work you can contact sony directly at:
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
  • Remove any obstructions from the vents.
  • Allow at least 4 inches of clearance on all sides for the PLAYSTATION 3.
  • Remove the PLAYSTATION 3 from any cabinets so it is out in the open.
  • Shut the PLAYSTATION 3 down completely and let it cool down to room temperature, then try running it again.
  • If the fan cannot be heard before the system shut down, the PLAYSTATION 3 may need to be sent in for service.
  • If there is no airflow from any of the vents, the system may need to be sent in for service
Hope this helps. Also be sure to rate whether this helped or not.
Jun 24, 2009 | Sony Playstation 3 (PS3) Console
PS3 shut down during mid-game/now it will not eject the game disk
not a solution but a possible answer it is possibly the ylod (yellow light of death) it seems a few people are getting this and my ps3 has broke aswell even sony dont know what is wrong with it. but your problem sounds like the ylod
Jun 07, 2009 | Sony Playstation 3 (PS3) Console
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Sony PlayStation® 3 (60 GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
