Hi i have a p5s800-vm mother board when i power up it comes up with the log and pick tab or del then the screen goes blank and windows does not start need help
    Problem Solver:
  • 14 Answers
The damage is accur in moniter motherbord in mother bord the yok of picher is damaged
Posted on Mar 25, 2008
  • arvind kumar Mar 25, 2008
    sir
    the moniter is a problem is on moneter motherbord is yok.
  • 4 Answers
1) It could be due to some faulty peripherals...Try to boot after disconnecting CD drive and Floppy drive. Also, if you are able to go to BIOS , disable the unused ports like COM, inbuilt audio, onboard LAN etc. After this if you are able to boot , either one of the drives or some port in Motherboard may be faulty. Isolate by disabling one by one. Then remove the corresponding driver from windows if one is identified.
2) Try to boot in windows safe mode,If it is possible , remove the display driver and re-install it.
Try and get back
  • 537 Answers
So you get past the BIOS screen then your screen goes blank?
Can you press F8 just before Windows would load to see if the Windows boot menu comes up.
I would also check to see that you have no devices plugged into the USB ports. Printers/mice/keyboards are okay, but not USB drives, memory sticks. Some computers want to try to boot off of these devices and it can cause unexpected hangs or simply no booting at all.
Assembling a new personal computer with a P5S800-VM mother board... my computer will not start normally...
Hi, you can download a manual here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5S800VM/#download
Please select your operating system.
Select manual and click on global for download.
Unzip the file before you can read it.
Check the bios settings for boot options.
Sep 06, 2011 | ASUS P5S800-VM Motherboard
I have asus mother boad p5s800-vm/s. but i dont have mother boad drivers.pls sent me link to download. Thanks
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select drivers that matchesyour Windows operating system. Please click on this link to their WEB supportsite : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Apr 17, 2011 | ASUS P5S800-VM Motherboard
I dont know hwta is the model of my sound card and i cannot activate it after i formated my computer! my mother borad is ASUS P5S800-VM , can anybody help me to find the sound card activate download?
ASUS P5S800-VM Drivers
Please visit the above link from ASUS Official Support. Select the OS (Operating System) e.g.Windows XP and download the required Audio Drivers. Extract the 'Zip/ Compressed file' Double-click the setup exe file and follow the on-screen instructions to install the drivers
Hope it helps! Good Luck!
CreativeTECH
Feb 25, 2011 | Computers & Internet
Cant get bois to show up on screen
when you start the computer at the time u press del key contiuons upto the bios page not came then you can set up your settings
Mar 30, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
No sound after reinstalled windows xp pro
Yes you will need to re install the audio driver. If you do not
have the original cd for the motherboard, here is a link to the
Audio Driver that you will need.
Download Link:
http://www.driverstock.com/ASUS-P5S800-VM-driver-download/6-9-10176-81148/index.html
Let me no if i can be of anymore assistance.
Mar 15, 2009 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM mother board V Asus EN9500GT graphic card
you would need a new mother board or change the graphics card
Feb 11, 2009 | ASUS P5S800-VM Motherboard
P5s800
The fact is because the motherboard's Video Card Has BEEN overheated. You may need to buy a new video card
Aug 17, 2008 | ASUS P5S800-VM Motherboard
I don't have mother board cd
Hi, I am confused regarding the model of the Mother board
you have:
The P5S800-VM is an LGA775 socket mother-board for a
Pentium 4 CPU.
P4-515, on the other hand, does not return any hits on the
Asus web-site search.
I think your best solution is to contact ASUS /USA:
1-888-678-3688
and talk to customer support.
They will guide you in identifying the exact motherboard you
have, so you can download the driver set from their
support site.
BTW.
I think you computer performance is very unbalanced at 256 MB.
This is not nearly enough memory to run with such a fast CPU,
(2.93 Gigs), and your machine must be terribly disk bound:
1) When your operating system runs out of semiconductor
memory, it begins to thrash to disk, which is 10 million times
slower then RAM, making the fast CPU a total waste of
money.
2) For a normal machine running Windows and a 3Gig CPU
you should have at least 1 GB of RAM, preferably 2GB
(RAM is cheap these days)
But before I put my foot too deep into my mouth, I notice that
you are running FREEDOS, does that mean you are running
DOS only (No Windows ?) for some specialized application ?
Martin
Jul 20, 2008 | ASUS P5S800-VM Motherboard
I have Asus P5S800 main board
dr-afacan, You unfortunatley are not giving me a lot of info to work with. There could be several things to try. First check your cases front panel to Board connections. Then if they are correct I would swap out the power supply with anything compatible to check and see. If that PS is really OK. If you do not have the info for the board go here http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5S800-VM/e1767_p5s800-vm.pdf
Next step would be to either check the processor, possible BIOS settings or update. Or you unfortunatley just have a dead board. Asus has a good customer RMA system... Just some thoughts.....PCdok
Oct 14, 2007 | ASUS P5S800-VM Motherboard
Computers & Internet Logo
David Payne
David Payne
