Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
The shifter is very hard to shift from neutral into any gears on a sears craftmans 14.5 hp grey colour machine
  • 29 Answers
Check to see if your belt is stopping when clutch brake is depressed.
Posted on May 01, 2010
Won't reverse. 1st gear seems to be in neutral position according to shifter.2nd gear in 1st gear position and so on. Shifter is hard to move?
Need more info. What Machine? Was it working fine on your last mow and then just act up when you started to mow again?
Did you look at where the Shift Lever goes to see if it is bent or obstructed?
Oct 06, 2015 | Garden
1998 arctic cat 300..... hard to shift you have to
I do not know much if anything about an arctic cat but if you have a shifter you have some kind of a transmission and if you need to get it into gear or neutral but cannot do so without rocking the machine or the shifter back and forth a slipping clutch would not likely have anything to do with the problem. You likely should not be trying to shift gears with the clutch engaged and the clutch normally should be FULLY slipping ie completely disengaged when you are shifting. It sounds like you could have sticking shifter linkage parts, worn shifter parts or internal transmission parts, bent shifter forks, worn shifter cam or drum grooves or shifter fork pins or other worn parts or maybe even low or no transmission fluid.
Oct 05, 2014 | Cars & Trucks
Xjr 1300 goes in all gears easy when not running but when it started it hard to get into gear and wont go to neutral unless turned off any help most appreciated
Hi, Anonymous and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. A loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
demo ride hard shifting question
http://www.r1-forum.com/forums/105-07-08-r1-mechanical-help/320723-only-when-hot-cant-find-neutral-hard-shift.html
Yamaha 2002 XJR1300 Service Manual
OEM parts for Yamaha
http://www.yamaha-xjr.cz/download/owners_manual_2001.pdf
Jun 10, 2012 | 2000 Yamaha XJR 1300
Can not select neutral on yamaha fazer 1000
6. The shift lever is loose on shifter shaft.
Yamaha Fazer 1000 or FZ1 gear shifting problem
Yamaha FZS1000 2001 Service Manual
YAMAHA FZS1000 Owner Manual
Feb 26, 2012 | 2003 Yamaha FZS 1000 Fazer
I have a xjr1300 2001 and it is hard to get neutral gear
Hi, Lowfieldss and the usual suspects are:
Why is my bike so hard to get into neutral
1999 2003 Yamaha XJR1300 Service Manual Moto Data Project
YAMAHA XJR1300 Owner Manual
Aug 02, 2011 | 2001 Yamaha XJR 1300
Stick shift
Hi:
The shift pattern is pretty much the same on all 5 speed cars. The top row is the odd numbers, 1-3-5
the bottom row is 2-4-Reverse. The center position is neutral
Here is the key: The shifter is slightly spring-loaded to the center position. If you hold in the clutch pedal and pull the shifter to neutral, and let go of it, it will automatically be lined up in the position, that if you pushed it forward , it would go to 3rd gear, and if you pulled it back, it would go into 4th gear.
This way, to start driving, you start out in neutral, grab the shifter lightly, and push it first to the left, then forward. This is first gear, where you start out. when you want to shift to second, push in the clutch, and keeping left pressure on the shifter, pull all the way back . Here is the easy part, 2nd to 3rd. When you are ready, push in the clutch, and just push the gear shift forward , till it hits neutral, and is spring loaded to the middle. Then you just push it straight forward to 3rd, then next shift, straight back to 4th.
Last gear, 5th: push forward to the neutral row, then Push to the right till it lines up ,and forward to the 5th gear. Reverse should only be shifted into from a dead stop. Find neutral, push the shifter all the way right, then pull back towards you. Hope this helps.
Practice a bunch in the driveway!
Apr 21, 2010 | 2001 Hyundai Elantra
'92 softtail 5 speed only has 1st & 2nd gear
It will be hard to shift or find neutral if the clutch isn't adjusted right. check your adjustment first.
Feb 09, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Shifter seems to have shifted
just ram the shifter in your booty,.....duh
Dec 31, 2008 | 2003 Toyota Celica
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
316 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
