Question about HP Pavilion F1703 17" LCD Monitor
Speakers are hard to understand cutting in and out
My speakers to m pc is cutting in and out can't understand them, i have a vista
    Problem Solver:
  • 14 Answers
PLEASE FORMAT YOUR SYSTEM AGAIN I THINK I WILL OK
Posted on Mar 25, 2008
My system configuration is like this: -intel core 2 duo processor -2 gb ram -500 gb hard disk -intel DG41RQ motherboard -microtek ups 1kv -pinnacle tv tunner card -4.1 creative speakers -vista 32bit os i...
CHECK FOR UPS AND OTHER POWER OPTIONS UNDER PROPERTIES..
U CAN OPEN PROPERTIES BY RIGHT CLICKING ON DESKTOP AND
THEN SELECTING PROPERTIES FROM THERE...
A DIALOG BOX WILL APPEAR AND IN THIS SELECT POWER BUTTON
AND UNDER THIS SELECT UPS ...AND SET ACCORDINGLY THE
UPS SETTING...
IN THIS U CAN CHANGE THE SETTINGS SO THAT YOUR AUDIO WILL
WORK...
DONT FORGET TO RATE ME AND VOTE ME IF THIS WORKS....
AND I KNOW IT WILL SURELY HELP...
Jun 24, 2010 | Intel Computers & Internet
I have the above system - HP Pavilion dv9933cl. Came with Vista. I scrapped this, flattened the drive and upon attempting to install XP Pro...am dealing with the "hard drive not found". Been searching and...
The newer systems do have to have drivers for everything. The best way to do this is to reinstall Vista, it has a hard drive manager built in and you can cut the hard drive in half or cut it as big or as asmall as you want. Then install XP on the second half install a boot up manager and have two systems on one computer, this is how i did mine. I used Vista till I got My Xp running like I wanted and I use Vista very little now.
Jan 14, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
The small speakers produce sound but the sub
I have Boston BA745 speakers and want to use them with my new HP Pavillion Elite HPE computer. How do I get them to work?
Dec 27, 2009 | Boston Acoustics BA745 Computer Speakers
I have a jbl 525 powered speaker but it wont play full range it will come on and out, playing only the highs at times
Check the incorporated capacitors (if any), also inspect the braid speaker wire on the bass speakers (i understand that these are cutting out).
The braid wires are located between the speaker connection terminal and the speaker cone - if these are damaged or broken, this can cause the speaker to cut out intermittently. To see if this is the case, try to push the speaker membrane gently inward when the speaker cuts out - if it momentarily regains function, then the braid is almost certainly damaged.
Braid wires can be resoldered, but it's not a very easy task because of the structure of the braid, which makes it difficult to clean and solder.
You should have it repaired by someone with good soldering skills or at a speaker repair shop, otherwise the alternative is to replace the speaker.
regards
Triarcuate
Sep 29, 2009 | JBL 6-1/2\ Round Coaxial Speaker By...
Can't Hear Any Sound. Only Just Got My PC Back After 3 Weeks With A Short Cut In The Motheboard, Now Everything Is Fine There But The Tech Man Installed Vista Why'? I Don't Know But When I Get My System...
I would complain about Vista--many problems with vista--I cant believe the tech would do that without your consent..why do you think they are offering back XP as an option on new computers?
Jun 04, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
How do I move some data to external hard drive?
Simple Purchase a new External hard drive .Connect It and cut Paste your data to move....
Apr 12, 2009 | Microsoft Windows Vista Business Edition...
Speaker setup
This is a hard problem when one is not looking at the speaker. But let me give you a little help if I can.
Try pluging the subwoofer into the speaker port of the Pc
Make sure your pc is turn of.
2) I believe the subwoofer has four jacks at the back.
3) Plug each of the speaker into the jack that says speaker
4)Now, if you are confuse of the in and out, on the subwoofer I understand. I believe you should be from out of the subwoofer to the in of the speaker. again, I cannot see at the back of you subwoofer.Only speaker from exprience.when you are done, turn your pc back on and turn the speaker on. making sure the volum is turn low.
good luck
Jun 18, 2008 | Harman Kardon Audio Players & Recorders
Installing Windows XP alongside Vista
First you want to install xp and then only you want install vista because higher version will not take lower version.
Feb 26, 2008 | Microsoft Windows XP Professional for PC
Krzr noise suppression is so intense that the first letter or sylabel of words is cut off making it hard to understand what people are saying, is there a way to adjust it or turn noise suppression off?
You problem could be one of two things. Either your internal speaker has been blown, and the speakers in Motorola's are known for that. Or your not getting a good enough signal although it shows that you are. Which Motorola's are known for too. Take it to your service provider. Hope this helps!
Aug 16, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
HP Pavilion F1703 17" LCD Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
