Question about Sony Playstation 3 (PS3) Console
Ok...when I turn ON the PS3 it goes to main menu. When I insert disc, nothing change on screen and not even loadind or reading it. You can hear the disc spining,the drive pulls it in and thats it, I had deleted every single thing which I store prior to this problem and also update the system and software via internet. and its still doing the same thing. Sometime when you try to eject disc,it takes more then 2 minutes to eject disc. I had tried my PS3 games and also DVDs but didnt work..Please help. Thanks Ronald
    Novelist:
    Champion:
  • Sony Expert
  • 207 Answers
What you have is a problem thats hard to diagnose.
the easiest thing you can try is to clean the lens.
along with checking the cables that connect your drive to the motherboard and etc..
if that didn't work you can try replacing the whole drive -- *NOTE* if you do change the drive make sure you buy the right type and also when u buy a new drive you will be getting the drive/moter only and not the control board that is attached underneath . you'll have to put your old control board onto the new drive
hopefully you get your drive working after these steps if not you will be getting into more complicated fixes.
this is one of the sites that i come across alot that fixes different ps3 problems
http://www.gophermods.com/index.php?l=product_detail&p=7
still if that didn't work you may need to replace couple of things on the drive board which can get very technical. very technical because in 2 ways.
1) your ic chip may be bad and you could try replacing that on your control board but that involves desoldering/soldering near many other component of the board. very trickly
2)if after you replaced the chip and it still didn't work you may have more than 1 problem on your control board in which case you just need a new control board but the thing is there is another chip that (the nand chip which holds the firmware of your ps3) is married to *********** board and without that chip your ps3 will not read/load/operate any of the disk or downloaded games on your ps3 hard drive. so just swapping the control board won't work. So you'll have to buy a new control board and swap out the nand chip. again very technical and not for a novice. even some repair shops send it off to do these fixes to a more specialist
if your ps3 is still under warranty its just best to send it off to sony and let them fix it for free. they cover your system for a year from the date of purchase. and you may or maynot get your original system back. check youtube for "replacing ic chip on ps3" or "replacing nand chip on ps3" you'll find that some people have actually fixed their systems.
Posted on May 01, 2010
Ps3 not reading disc..Please help
Do you see the little clock like icon in the top right corner of the screen when you first insert a disc the loading disc icon? if so then it could either just be the drive itself or a software issue in which case you can try a few things before replaceing the drive.
First just reset to factory default settings under system settings.
P.S. i assume its not reading any kind of disc if it isnt reading anything also double check to make sure the disc you are using are still good and not just really dirty or scratched. GIve us more info and what disc your trying to check so we can further help you out.
Justin
Apr 29, 2010 | Sony Playstation 3 (PS3) Console
My ps3 turns on and off ok, plays movies off the hard drive and will play ps3 games but has suddenly stopped playing movies ( dvd & blu ray ) it recognises the disc and goes to play it but the screen...
That is actually a poor conclusion. There are three different lasers, one for blu-ray, one DVD and one for CD games all in one holder inside. It certainly CAN be the laser. The description id the DVD/Blu-ray part is having focus problems. Contact Sony for a service center that can install a new drive (It needs to be calibrated on install)
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
Blank screen, not reading dsc
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
Disk not reading
I had a similar problem. My PS3 was not starting the game discs when I inserted those to PS3. Also those game discs were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
NO output either HD or normal tvs (not on/off botton hold prob)
Hi, The fact that you are getting a load icon when you put a disc in makes me think you have corrupted system files. If you have a spare 2.5 SATA drive you could put it into the PS3 and let it auto-format it, see if that gets the menu back for you. If it does then your current drive probably needs to be reformatted on a PC and then re-inserted into your PS3.
You'll lose your save games (unlesss you can back the drive up on the PC).
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Discs wont read on ps3.
Question: does it play blueray movies? Mine did this, but would still play movies. I found a "Corrupted Data" file in my Games/data folder, and ended up doing a quick restore, under ths System menu. I now have no problems in this area...games start properly every time. You will lose all your saves and any dowloaded content, so back up if you can.
Dec 05, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont load games up
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Nov 18, 2008 | Sony Playstation 3 (PS3) Console
Wont play games or movies
my playstation wont play ps3 games but it will play movies and ps2 games.if i put a ps3 game in it frezzes...
Sep 19, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
83 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
