Question about EliteGroup P4M800-M7 Motherboard
USB 2.0 (Chipset VIA 8237) ECS P4M800-M7 Unknow Device
My S.O.: Windows XP Professional SP2 PT-BR (Brazilian Portuguese)
My Motherboard: ECS P4M800-M7 (Chipset VIA 8237 - 4USB 1.1 and 4USB 2.0).
When plugin my pendrive Kingston 1g 2.0 in USB 1.1 know sucessful.
But plugin my pendrive in USB 2.0 don't know my device.
All is properly connected. The driver installed is the of the Microsoft Windows XP SP2. Into the site from VIA don't have drivers xp SP2 only to SP1. In some foruns what find the Internet they say what that's a problem of the chipset VIA. Don't know solution. They say too that can be a bug of the driver HUB usb 2.0 and the microsoft sends the patch for email (there isn't link for download). I send a email, but the Microsoft dont answer me.
Very Thanks,
John Felix
  • 4 more comments
  • JohnFelix777 Mar 26, 2008
    I already reinstalled the drivers. I do format the computer, but don't worked.
    In "other" computer worked when:
    format with XP SP1
    Install driver official VIA
    Install SP2
    I don't have more XP without service pack or with sp1 for try this computer.
    As I had said I believe even be a particular problem this chipset.
    There is a known problem with HUB USB 2.0 (poor supply of energy) but the microsoft only send by mail and did not believe that version for the language of my XP, since microsoft not answer my request.
    See what I did:
    Uninstall original driver USB.
    Install driver USB with XP disc (Windows XP Integrated with SP2).
    And don't worked.
    Install original driver VIA USB for XP SP1
    And don't worked.
    Format computer with Windows XP Integrated with SP2
    And don't worked.
    The USB 1.1 in all attempts worked. Just USB 2.0 don't worked, show Unknow Device.
  • oshawkat Dec 04, 2008
    when i connect my flash memory to all USB connection the PC could not recognize it
  • su7lo_aja Dec 10, 2008
    my usb device dosn"t work ( unrecognice) how to solve this?
  • valdofredo Jan 21, 2009
    After install XP SP3, my USB cant mount Pendrive Letter. U uninstall ir, but now I cant reinstall my USB 2.0 VIA VT6202 Host Controller Driver Package, even from original CD Mothterboard Driver.
  • Anonymous Mar 13, 2014
    BIOS pour ECS (Elitegroup) P4M800-M7 (V3.1)
  • 655 Answers
Hi, John
The USB 1.1 and USB 2.0 is a big issue regarding technology, the 1.1 has maximum speed of 12 megabits where as 2.0 has upto 480 Mbps. And all USB 2.0 devices are compatible with 1.1. Windows XP Home Edition and Windows XP Professional are both fully USB 2.0-compliant with the correct drivers.
So in your case it must work properly. But if the USB 2.0 from microsoft got currepted or badly updated by some thirdparty USB 2.0 driver then it will not work. I have been faced this problem. After doing some stuff I found that if I uninstall the USB drivers and reinstall it from microsoft driver then it works.
So, just go to the Device manager and un-install the USB drivers, then reboot the system to parmanently delete the removed driver. Then install the driver from Windows XP CD.
good luck
Thanks
Iqbal
Posted on Mar 25, 2008
6ya staff
SOURCE:
I have a ECS P4M800-M7 (V3.1) motherboard , does this motherboard supports Intel Dual Core E5700 ?
this motherboard supports the following
LGA775 socket for Intel Pentium 4/ Celeron D/ Pentium D processor
FSB 800/533 MHz
so anything above that might not work or just simply be a waste of money
the e5700 will fit as it's the same socket configuration as the motherboard but here's the rub, the 5700 is only compatible with motherboards that have intel chipsets and, according to the website, your motherboard doesn't have an intel cjipset, but a via chipset.
so the simple answer is no!
http://ark.intel.com/Product.aspx?id=42801
http://www.ecs.com.tw/ECSWebSite_2007/Products/ProductsDetail.aspx?detailid=548&CategoryID=1&DetailName=Specification&MenuID=52&LanID=0
Apr 17, 2011 | EliteGroup P4M800-M7 Motherboard
I want to know whether this motherboard support window 98 with windows xp
Check these links to solve your query
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=531&CategoryID=1&MenuID=16&LanID=0
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=548&CategoryID=1&MenuID=16&LanID=0
Jul 19, 2010 | EliteGroup P4M800-M7 Motherboard
I need a user's manual for my Via P4M4A Pro mainboard. Via won't respond to my requests. Help!
Hi.
Via usually only make the chipset - not the motherboard. Find the manufacturers model number printed on the motherboard then go to the website and download the manual.
If you had for example an ECS P4M800-M7 you would go to
http://www.ecs.com.tw/ECSWebSitP e/Products/ProductsDetail.aspx?detailid=531&CategoryID=1&DetailName=Manual&MenuID=1&LanID=0
Jan 19, 2010 | VIA Computers & Internet
Graphic drivers for motherboard P4M800-M for windows xp 32 bit
Driver can be found here. For other drivers related to this board, visit the ECS Site.
Apr 21, 2009 | EliteGroup P4M800-M7 Motherboard
An error occurs "usb device not found" when using flash drive or
you can connect your usb at back of cpu,,,,,may be it work.you should connect your usb on different ports
Mar 11, 2009 | EliteGroup ECS P4M800-M7(3.1) LGA775 ALL...
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
5,352 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
