Question about Microsoft Xbox Console
How to clean a disc so you can play it
How to clean a disc
  • 186 Answers
Warm soapy solution wipe clean cloth that should do it ok;
Posted on May 01, 2010
Tip
How to clean a disc
  • Many times, all that a disc requires is a quick dusting, ideally using a soft cloth which has been specifically designed to clean a CD. To remove dust from a DVD or CD, use a soft, lint-free cloth. Hold the disc in a pincer grip with one finger along the edge and another in the hole in the middle, without touching the shiny portion,and gently move the cloth radially outwards from the middle. Do not rub the disc or move the cloth in circular motions, and make sure to avoid following the circular lines on the disc.
  • If the disc still looks dirty after dusting or if you are having trouble playing it, a more serious cleaning effort may be required. Several companies make special chemicals for the purpose of cleaning DVDs, but you can also use household cleaning supplies. One of the best cleaners is rubbing alcohol, but you can also use a warm water and mild soap solution instead if you wish. Avoid any heavy duty solvents when you clean a CD, as they can damage the disc.
  • Apply the cleaning solution to a clean lint-free cloth, and wipe the disc, again radially. When you clean a CD with a liquid material, make sure to wipe the excess liquid off, and never put the disc back into its packaging when it is still wet. Allow the cleaned disc to dry completely before attempting to play it again. When you clean a CD with alcohol or a specialized cleaning solution, many times the cleaner dries so quickly that this is not a major concern, but check for spots and/or marks which may interfere with clean play.
  • Even after cleaning, a disc may fail to play properly because of scratches. Some companies manufacture products which are designed to resurface discs, smoothing out scratches so that they will play again. Depending on how severe the damage is, these products can be quite effective, but it is a good idea to back up the data as soon as you have repaired the disc, in case it could fail again.
Let me know how this works for you.
Benjamin
on Jan 06, 2011 | Philips Magnavox DVD/VCR Dual Player
Tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
on Feb 18, 2010 | Video Game Consoles & Games
How do you clea a disk
  • Many times, all that a disc requires is a quick dusting, ideally using a cloth which has been specifically designed to clean a CD. To remove dust from a DVD or CD, use a soft, lint-free cloth. Hold the disc in a pincer grip with one finger along the edge and another in the hole in the middle, without touching the shiny portion, and gently move the cloth radially outwards from the middle. Do not rub the disc or move the cloth in circular motions, and avoid following the circular lines in the disc.
  • If the disc still looks dirty after dusting or you are having trouble playing it, a more serious cleaning effort may be required. Several companies make special chemicals for the purpose of cleaning DVDs, but you can also use household cleaning supplies. One of the best cleaners is rubbing alcohol, but you can also use a warm water and mild soap solution. Avoid any heavy duty solvents when you clean a CD, as they can damage the disc.
  • Apply the cleaning solution to a clean lint-free cloth, and wipe the disc, again radially. When you clean a CD with a liquid material, make sure to wipe the excess liquid off, and never put the disc back into its packaging when it is still wet. Allow the cleaned disc to dry completely before attempting to play it again. When you clean a CD with alcohol or a specialized cleaning solution, often the cleaner dries so quickly that this is not a major concern, but check for spots and marks which may interfere with clean play.
  • Even after cleaning, a disc may fail to play properly because of scratches. Some companies manufacture products which are designed to resurface discs, smoothing out scratches so that they will play again. Depending on how severe the damage is, these products can be quite effective, but it is a good idea to back up the data as soon as you have repaired the disc, in case it fails again.
Let me know how this works out for you.
Benjamin
Jan 06, 2011 | Microsoft Xbox 360 Console
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    My 360 only plays cds or dvd s wont play games please advise
    Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
    Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
    Feb 15, 2010 | Microsoft Xbox 360 Console
    Audio and dvd disc wont play
    If you are inserting a clean Disc without scratches, but the device couldn't play it, then your disc's head needs cleaning or maybe defective already. Please check if it can play some other discs.
    Dec 27, 2009 | Computers & Internet
    Sony cdx 4000x cd changer
    Is it now, not playing disc's that it used to play? If this is the case, the laser pick up either needs to be cleaned (with cleaning disc) or it needs to be replaced. If cleaning it does not help, the pick up is getting weak. When this happens, it will only play disc's with a high reflective surface. Store bought disc's have the best reflective surface. Burned disc's are not as good. Some burned disc's are better than others. The disc's with a blue or green data side are the highest reflective surface for burned disc's.
    Sometimes the disc's can not be played because of the condition of the disc. If it has a lot of scratches on it, the player will have problems if those scratches are deep or if they are in the area of the disc that the TOC (table of contents) is written on the disc. Thate area of the disc is in the inner most area of the data side of the disc. The cd player must read it first, then it knows where to find all the songs and all the information for the songs.
    Fingerprints are also a problem for cd players. A fingerprint will bend the light from the laser and make a disc unplayable or cause a lot of skipping.
    The first thing to do is to clean your disc's. I use windex and a soft cloth like a bath towel. It cleans cd's and dvd's as good or better than any of the disc cleaning kits you can buy at a retail outlet.
    Next, get a cleaning disc for the lens of the laser pick up. Run it for about 20 to 30 seconds and then take it out.
    If these things do not help, you may just need the laser replaced. That usually runs about $125 or so depending on the rates of the shop you take it to.
    I hope this helps and a Fixya rating would be appreciated for this free information.
    Thanks, and let me know if you need any more help.
    Dave
    Jul 15, 2008 | Car Audio & Video
    Error message E08
    You said you cleaned the player but did you clean the disc? Any scratches, dirt debris? To clean the disc you can but special cleaning soultions at various retailers. Have you tried playing diffrent discs, that will help rule out if it's the player or disc.
    Sep 12, 2007 | Jensen XCH6RF 6-Disc CD Changer
    Playing DVD'S
    If you sure that the system supports the disc's format.. And it play other only once... try to clean the CD lens.
    Dec 31, 2005 | RCA B27TF680 27 in. TV/VCR/DVD Combo
    Microsoft Xbox Console Logo
    18 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
