Question about Frigidaire Freezers
We have a side by side and my husband cleaned out the ice cube tray. But now the motor for the ice maker keeps running. It stops when the door opens, but of course it has to close. I am afraid that the motor will burn out and we will loose our whole fridge. What do we do! I can't afford a new machine. We are both out of work.
  • 3 more comments
  • dwlasvegas May 01, 2010
    Hi, The model# FRS22ZRG
    OK, so I took the toe kick off but i don't see a wire connector. I do have the corner piece directly under the door. Does that need to be removed? It looks like it is riveted on though.
    No, I don't see anything on the top either.
    Ok, thanks. Can you please email to dwlasvegas1@cox.net (adding the 1) I am having trouble with my other computer and I am having to run up & down the stairs. Thanks
    Hi Phil, We found the wire connector and pulled it out. Is there anything else we need to do? Will this effect the Freezer at all? Is this expensive to get fixed?
    President:
  • 949 Answers
Have you tried to 'lock' the control panel on the outside of door where the ice is dispensed?
Can you send me the model number from the tag just inside the frig, this will help me when telling you what needs to be done.
Thanks!
Posted on May 01, 2010
  • 5 more comments
  • Philip May 01, 2010
    Okay thank you. We are going to have to disconnect the power that operates the motor. The easiest way is right up front. Can you take the toe panel off the bottom below the doors, the grille that covers the coils. It should pull straight off. Then look on the left side just below the freezer door hinge there should be a wire connector, unplug that connector. Let me know when you get that far
    You should not have to remove anything that is riveted. If the wire is not coming to the bottom it might be in the upper hinge under the cover.
    What we are trying to do if find the power wires to the dispenser front the feed into the door usually through the bottom hinge, but it may be on the top hinge on this model.
    It is showing on the diagram it is on the bottom, but since you cannot see it, I thought we would take a chance on the top.
    We can go another route if you can't see the wires on the bottom. We can disconnect behind the dispenser panel. It would be best to unplug the refrigerator for this. I will pull up a picture and be right back to send to you.
    Here is a link to a picture of your dispenser taken apart.
    http://www.searspartsdirect.com/partsdir...
    I will find the wire to disconnect and get right back to you
    Once we get the dispenser front off we will need to disconnect the switch that activates when you put a glass under the chute
    Fantastic! No this will only effect the dispenser for the water and ice
    The part that has gone bad is about $30.00, it is getting to it that is a bear. It is one of the switches inside that dispenser housing. I am not sure which one it is, so it would have to be tested with a meter. That is what was taking me so long, I was trying to figure out by the wiring diagram and picture which switch it is.
Managemylife com sears
check that the ice maker is not jammed with frozen ice
dont force the tines on the tray to turn . lightly geared clock.
can you hear the little clock motor running quietly wirrs
is the water running out the front ok
is the water frozen before the tray ,defroster issue then
hit it with a hair dryier for a few mins an see what it does when u close it .
Jul 25, 2014 | Samsung RSG307AARS - 30 cu. ft. Side by...
Ice maker will not separate ice cubes
Check if your water filter is up to date, if not check if the ice maker has the option to choose the side of the ice cubes, if so, set it up to medium side.
Apr 05, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Ice maker is making ice cubes AND pouring water
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Aug 07, 2009 | Freezers
Ice maker only fills the tray partially.
There is an adjustment, but first check your filters, including the one in the inlet of the control valve. To find the adjustment, take the cover off the front of the ice maker. On the side may be a little hole. Look for any 'increase' arrow or such. If not, use a small screwdriver to turn the adjustment a half turn and let it make a load of ice. If it gets smaller, go the other way, use small adjustments. If you can get the owner's manual, it will help a lot. Google your unit for one, you may be able to get it downloaded free from Whirlpool.
May 05, 2009 | Whirlpool Freezers
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
Thin Ice on Whirpool Ice Maker
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Apr 05, 2009 | Whirlpool Freezers
Freezers Logo
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
