Question about Curtis-Mathis CM19011 TV
What station do you put the TV on to play a DVD?
  • 100 Answers
Use source control and select which ever av input your dvd player is plugged intoor if there is an av button on set or remote use that
Posted on May 01, 2010
I moved my vhs dvd combo and it does not show on tv altho it says play
make sure that you have selected the right input from aerial to dvd
AV1, AV2 AV3 etc
Oct 24, 2015 | Televison & Video
What do I need to connect an old TV with only one output on back to a TWC cable box, DVD Player, VCR and a Play Station?
Just connect the PS3 it also works as a DVD player. Do you really need a VCR player? You can get a converter box to stream the VCR footage through the DVD player/ PS3
Aug 06, 2012 | Televison & Video
What fuctions does my remote do and how.and why cant i get a dvd to play
Consult owner manual about hook up and if no picture on DVD or does not play them at all either mechanism or optical pickup in that unit is dirty or bad.
Apr 17, 2012 | Panasonic PV-DM2093 Triple Play 20 in....
Hi, i bought this dvd player in australia and have since moved to new zealand. will all the tv features work?
The DVD player will play Region 4 DVDs both in New Zealand and Australia. If this player has a TV tuner, then the stations may need to be set/scanned for NZ stations.
Sep 29, 2010 | Computers & Internet
I have cable tv do not know what station to put on to play dvd
Go to your menu or input button and switch to eather input1 or input2 depending on witch inlet u have your DVD attached. there also may be a switch on the back of your DVD player marked 3 or 4 put that to the chanel ur TV is set to for cable most likely cnanel 3
Nov 28, 2009 | RCA Televison & Video
None of the buttons on the TV will work...can't turn TV off
Hi you will need to reset your Tv & remote sounds like that children may have played with the remote reset should clear the problem.
Feb 19, 2009 | Funai MWC24T5 24 in. OLED Television
I have an Archos 605 WiFi. I haven't yet connected my Archos docking station to the TV and HDD. Meanwhile, I thought I would copy a programme from the HDD to a DVD, then put the DVD in the computer and...
What kind of HDD do you have, do you have any type of output on it. You stated that you haven't connected the docking station to it and the TV...? The best thing to do is to connect your Archos to the Docking station. Set the docking station up correctly, with cables coming out of the HDD (if it has some sort of output) to the station and out of the station to your TV. Once you set that up, you can use the Archos as a mini DVR or VCR. Go to the REC option on the main screen of Archos, you'll have an option for Video Recorder (tab on top). If you play any source on the HDD, then all you have to do is press the Rec option on the Archos. If you already have a file on the HDD, then try just moving it over into the Archos once you connect the Docking station to your computer via USB or just use the USB cable connected to the computer with the HDD. I use the USB preference as Windows Media Device. (found under menu/settings/system). Is is basically a HDD itself. Remember the Archos will only play certain videos without the purchase of any extra plugins.
Good Luck
Apr 14, 2008 | Archos 605 WiFi Digital Media Player
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
No audio
FM station 88.1 or similar. Set radio to scan while dvd is playing. When the correct frequency is reached, you'll hear sound.
May 06, 2007 | Blaupunkt DVD-ME2 Car DVD Player
Curtis-Mathis CM19011 TV Logo
87 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
