Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
My designs are not full enough, How do I make the designs without the underneath fabric showing thru?
  • 64 Answers
Except the low density the problem could be caused by removing very small stitches before transmitting to machine because they cannot be accepted by it. It happens if the design was not properly resized or converted many times into different formats etc. You can use Design->Optimize function for removing small stitches before sending design to machine in order to examine its quality.
Posted on May 02, 2010
    Genius:
  • 1,116 Answers
Posted on May 01, 2010
My Toyota 444 sewing machine. When sewing,stitches ok on right side of material but underneath,stitches are entangled. sometimes it stops sewing and I have to pull thread out.
ALWAYS RAISE the presser foot when threading the top thread. (You will need to remove the top thread from the machine and rethread from the beginning.)
For tension, start out with it set about the mid-point on the tension dial. Then tweak it from there. If top thread is showing on the bottom of the fabric, tighten the top tension. If bobbin thread is showing on the top of the fabric, loosen the top tension. It's ideal when both threads meet in the middle of the fabric.
Sep 12, 2017 | Toyota Sewing Machines
Elna 2005 I don't have the manual. Which setting is for the stretch stitch?
A special stretch stitch is not required to sew stretchy fabric. All one needs is a zig-zag that is wide enough and close together enough to allow the fabric to stretch without breaking the stitching thread. (Test it on a piece of scrap fabric you are using, give it a good tug and see if the thread breaks.)
NOTE: be sure to use a ball-point needle. A sharp needle will tend to cut the fabric threads and your stretch fabric will eventually develop holes and runs commonly found in knits.
There doesn't appear to be a manual for your machine, however, you can usually find a manual close to your machine model and the instructions will be similar enough to suffice. Perhaps you will find one with instructions for sewing stretch fabric:
ELNA Other manuals
Jan 10, 2016 | Elna Sewing Machines
I'm using Empisal Dressmaker 270D sewing machine. My problem is. When I sew the underneath cotton is loose
Usually, if the thread is bunching or looping under the fabric, the upper tension is too loose.. But if the bobbin thread is showing on the top of the fabric, the upper tension is too tight.
The tension is correct when both the upper and lower threads meet in the middle of the fabric.
Sep 26, 2015 | Sewing Machines
Free motion quilting with the Singer 3343
I don't use a foot - I just gently guide the fabric and create designs.Hope this helps.Jimmy
Mar 28, 2012 | Singer 3343 Mechanical Sewing Machine
I have a 5150 model and i am making cushion covers, but my machine is not sewing it does goes though the materal but showes no stitches.what can i do?
try using a larger needle if your needle isn't large enough for the material you are using the needle may go thru but the thread wont go thru far enough to catch. The needle may be the correct size but just not sharp enough, the thicker the fabric the faster your needle will dull and a dull neele never works correctly
Oct 29, 2010 | Brother Sewing Machines
Thread problems
Try unthreading the top of the machine and with the presser foot up (the one you put the fabric under) Use a piece of regular size yarn about 1 foot long and go around your top tension like you would with your thread and floss it back and forth then pulling the yarn in your left hand up so that the other one is short but not out, drop the foot down and pull the short end until the yarn comes right out. Re thread the machine with your thread again with the foot up and try it on a scrap piece of fabric first. Sometimes you need to do it a few times.
Jan 21, 2010 | Husqvarna Designer I
My sewing machine will not pick up the bobbin thread. It sounds normal and pulls the fabric through, but the threads do not intertwine. I had been having problems with the bottom thread clogging and...
when the needle pulls the fabric into the feed dog you dont have enough fabric behund the neelde when you srart, and the fabric gets caught in the feed and the bobbin case underneath clean it out anf change the needle they often get bent after they get tangled in the thread and fabric
Dec 10, 2009 | Bernina Sewing Machines
Bobbin thread tangling up
are you doing embroidery? if so turn off jump stitch cutting if possible. is the machine threaded correctly (pull needle thread out of machine and thread again with presser foot raised.
check for foreign matter in needle tension assembly. ensure there is sufficient needle thread tension.
the thread you see caught up underneath the fabric will be needle thread and indicates insufficient needle thread tension or something preventing the needle thread from being pulled up into the fabric (maybe a damaged bobbin case, or bobbin case position finger, or damaged needle plate hole).
goodluck,
scott
Jul 27, 2009 | Baby Lock Ellure
I have a Kenmore 19606, I have never own a machine that does embroidery stitches, the pattern of the stitches shows on the wrong side of the fabric not the right side. Is this suppose to happen? If not how...
Not sure if you are doing embroidery w /a hoop and all, which I don't do but I have lots of decorative stiches . Ytp lacing some tear away interfacing below the fabric you are going to sew. Most stitches come out top to bottom. Say I have an alligator option. Image will be about 1 1/2 inch , Try it on a piece of scrap fabric to start. I used muslin and the tear away bnacking to stabilize the design on lettering and patters.Also use good thread. I like Guttermans. Coat and Clark / Sulky are very fine and snag and tear easily. Good luck. Keep trying. The design you sew will show on both sides , so if you do not want that you will have to add another level of fabric to the backside after completing the design. Hope that makes sense.
Mar 29, 2009 | Kenmore 19606 Computerized Sewing Machine
Fabric wil not feed thru machine
adjust your feed dog hight. manual shows u how
Dec 02, 2008 | Kenmore 15218 Mechanical Sewing Machine
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
109 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
