Question about Dryers
The tests checked out on my dryer from your suggestions yesterday.
I did the tests and i think it might be the main timer switch, but what wires do i check to tell if it is pooched. my wife is the one who originally wrote you and i just wanted to state that when we turn the knob to set the timer and push it in to turn it on, absolutely nothing happens. there is power going to the circuit board so its not the breaker. and thankyou for the already useful tips on how to check the other elements.
    President:
  • Dryers Master
  • 2,651 Answers
Umm yes woulda thought for sure a thermal fuse and/or elemnt would be the issue there, how about checking the door switch, if hte door switch doesnt make contact the machine would do nothing as well ( ptting your ear to the timer knob usually will hear hte low "ticking" of an energized timer, if you dont have that i would look to the doors witch. and dont be so quick to rule out a breaker issue either, its on a double breaker, quite possible that h1/2 your electric could be knocked out, completely turn off breaker and reset. to properly check for voltage at he unit you should have 240v. that would be( red to white 110v, black to white 110v, and black to red 220-240v) ifyou dont have that you have an electricla issue.
Posted on Mar 26, 2008
Have power everywhere but won't turn on
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 02, 2012 | Dryers
My civ60 tumble dryer gets hot for 10min then trips main switch
see the possible causes:
1) Unplugg the dryer from the wall, if the c.breaker of your house trips, the problem is in your house.
2) Connect again, and plugged the dryer, if the c.breaker the problem is some component attached to the dryer, a) Test for shorT in coil b) POWER CORD test for short c) Test the main motor for short and replace,d) Test any other devices, such timer, switch or some wires making contact with the chassis. or you must call some experimented electrician for to isolate the short circuit. God bless you see the diagram attached.
Jun 09, 2012 | Dryers
Dryer does not heat up model mdg508daww tested ignitor,radiant flame sensor,thermal fuse and tried limit fuse and cycling fuse checked blower wheel and made sure there was no air flow restrictions and...
A few other things that could make the dryer not heat are,
Heat selector switch on the control panel
Timer
Motor
A quick question though...i see where ya tested the ignitor but what i would like to know is does it glow or not
To test the heat selector switch ya need to use a multimeter set to measure ohms of resistiance and test the following to have Zero ohms resistiance when set to high heat setting
Red wire to blue wire terminal (wire must be removed)
Red wire to yellow wire temninal
The heat circuit on the timer is
Yellow wire terminal on the timer to the red wire terminal...on that too the wires need to be removed off of the timer
On the motor the heat circuit on the motor switch is the yellow/black wire to the black wire to determine if its good the igniter can be checked for POWER (120 volts) since the motor only sends power to the ignitor when the dryer is running because itsa built in safety feature that will prevent the dryer from heating when not running
Good luck,
GENE
Oct 03, 2011 | Dryers
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 21, 2011 | Kenmore Dryers
Trying to replace timer 8299771. Can't find my
On the new timer , you have 2 wires comming of the timer motor . The blue wire should go to one of these terminals on the timer itself . The place where there is ONLY a timer motor wire going to , is where it should go .
Sep 04, 2009 | Dryers
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity -  - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Roper electric dryer
go back to timer ck continuity with timer in any run postion from black to blue wire (i think..better ck wiring diagram under console..you're looking for the contacts in timer to make that control motor)
Sep 01, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
