Question about Magic Chef CTF2125 Top Freezer Refrigerator
Refrigarator seal refrigeratordoor is not closing tightly i see that the whiteseal around the door iscracked should i replace the complete door seal?
    Guru:
  • 1,524 Answers
Yes.
Posted on May 01, 2010
LG dryer doesn't dry clothes on one cycle. Lint collects around bottom of door rubber seal. Have noticed, the door is not closed tight. How to get door to stay closed tightly?
It sounds like you have a plugged up vent causing air to try to blow out around door instead of out vent. Also check door latch to see if anything is broken.
Mar 28, 2016 | LG Dryers
The ice dispenser often is loaded with ice cubes in large blokes frozen together.
make sure door seal is closed air tight use warm damp rag wipe around complete door both doors & freezer .
Mar 16, 2015 | Refrigerators
Icicles in the freezer and frost inside door of freezer. Normal for brand new refrigerator?
It sounds like the seal isn't closing completely. If there is any gap around the seal air is probably entering and the moisture is freezing. This sometimes happens when the doors are reversed. Try heating the gasket with a hair dryer if there are gaps in the gasket.
Sep 24, 2014 | Refrigerators
Refrigerator freezer stuck
I am guessing you are saying the freezer door is stuck closed and will not open? If this is the case you may need to pour some warm water around the seal until it is loose enough to open. After getting it open check the seal around the door, if there are places the seal is not completely sealed, then the seal needs replaced. Sometimes when the seal fails to seal properly moisture in the air seeps in and freezes next to the seal, eventually freezing the door to the box.
Jan 21, 2013 | Amana Refrigerators
Door will not close completly
When you say "oven door will not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 08, 2011 | Ovens
Seal around door is not tight. there are no breaks in the seal but the door doesn't seal properly. you have to make sure that you close the door tightly and when you close the freezer door it causes the...
Is this unit new? Is it new to you? Has this problem just developed? I need the history to help you. If it is new, you have a year warranty. All units built today are as air tight as possible. When one door is opened and closed. The other door can pop open. To alleviate this issue the unit's front levelers must be adjusted to tilt the unit back slightly. The door or doors might still pop open but will close by themselves. If I can help you futher, let me know.
Mar 30, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Light is still on and visible! when door is closed...gasket does not seal tightly. What should I do? Fridge is only 2 years old.
The seal will need to be fixed or replaced. The door switch does not shutoff until the door is closed completely. If it is twisted try a hair dryer to straighten it. If it is jamming on the hinge side vaseline might help. Possibly adjusting the door on the hinge may help. If you need a diagram or illustration enter your model # at www.appliancehelponline.com
Jun 24, 2010 | Refrigerators
Oven door will not shut tight at top
The door is not tight per say. The seal is hat determines if it is properly closed. Check to see if the seal is tight all the way around(use a strip of paper to check consistency). If it is not sealing the hinges are tweeked and need replacing.
Eric
Feb 22, 2010 | Kitchen Ranges
Door not closing properly.
take door off and pack bottom hinge with washers. make sure hingebrackets on cabinet are tight. however, door hanging a bit should not really affect sealing. if seal is gapping, one solution is to warm with a hairdryer and pull outwards gently
Mar 31, 2007 | Hotpoint RLA80 Refrigerator
Magic Chef CTF2125 Top Freezer Refrigerator Logo
105 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
