Question about Kenmore Refrigerators
On a Kenmore Refrig. #10654542400 which is the inlet on the water filter housing
    Guru:
  • 1,524 Answers
Installation: Simply turn the filter quarter turn to remove and replace.
Posted on May 01, 2010
Water is pouring from the ice maker on Kenmore side by side, model # 106.56662500
The reason all the ice freezes together and you see icecicles forming from the icemaker,is going to caused by the water inlet valve on the back of the refrig.is not fully closing but instead it's seeping water through it and dripping into the ice storage bucket. To stop that from happening the water inlet valve would need to be replaced.
On refrigerators that have a built in water filter,alot of times their will be 2 water valves and the one that is bad causing water to seep through it will be the one called the SECONDARY valve.
GENE
Sep 15, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water filter housing is leaking....can I by pass the filter by just coupling the tubes for right now until I can get the new housing?
To bypass it connect the line that connects to the house plumbing directly to the water inlet valve on the back of the refrig. behind the service panel.usually on the lower right corner when looking at it from the rear
Gene
Aug 06, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have a Kenmore Elite refrigerator with the freezer on the bottom. The water comes out of the water valve slowly when I want to fill up a glass. Why? It's the slowest flow of water that I've...
Restriction in the line. Check the water line to make sure it's not pinched or kinked.
Often times too the water line from the refrigerator is connected to the cold water line of the house with a self tapping valve. Turn the valve off and back on a couple times to clear any restrictions.
If everything is ok with the water line to the refrigerator then you will need to replace the water inlet valve behind the refrigerator.
Aug 03, 2011 | Kenmore Elite 78722 78729 Bottom Freezer...
I would really like some help with hooking up the ice maker. The line is there bit no ice or cold water, water is warm. Can you hep?
The routing of the water line is
house water supply into built i filter on refrig,
out of the filter into the water inlet valve on back of ref,
larger dimeter tube from valve into water tank behind crispers in ref,chills water,out to door,
smaller diameter tube from valve into icemaker
seeing where you said all lines are in place i believe the issue is that the refrig isn't properly cooling? the first to affected when not cooling is icemaker/water dispenser
Hope this helps
Gene
Jul 29, 2011 | Hotpoint HSS25GFP Side by Side...
Kenmore model 79578502800 refrigerator error code 1F. icemaker does not work
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Refrigerators
Ice maker not producing ice,already check the basic problems,
Jun 05, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Ice maker is not dumping solid ice. Half moons are still unfrozen in the middle
You need to replace the water inlet valve behind the refrig where the wall water line connects to on the refrig . This is caused by not enough water going into icemaker . Called " hollow cubes " condition .
Oct 15, 2009 | Kenmore Refrigerators
Kenmore icemaker
It sounds like the icemaker is making hollow cubes , and the unfrozen water in the cubes , after dumping , freezes and causes the ice shells to stick togather . This is a sign of " not enough water going into the icemaker " . Replace the water inlet valve , behind the refrig , the piece the wall water line connects to , on the refrig .
Oct 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
63 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
