Question about Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Picture is blinking - Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight and/or an inverter board issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 01, 2010
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
Apr 02, 2016 | Panasonic Viera TC-P65S1 65 in. HDTV...
42 inch philips lcd no picture no sound
Sometime a no picture, no sound still has the power light or some other led blinking. The blinks might be an error code that will isolate the problem.
In general on LCD TVs with no picture, no sound, no blink code, the main power supply has failed. The capacitors weaken and when bad enough, damage the power supply.
If there is a blink code, the most, if not all of the power supply is OK and the blink code could point to the problem.
Jan 19, 2011 | Philips 42PFL7422D 42 in. LCD TV
My picture shut off. Power lite clicks, blinks,no picture
how many times is the power light blinking as thats a error code. 3 blinks is the most famous which means convergence circuit failure.
Oct 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Picture blinking
Most likely you have a few dry capacitors on the power supply board, if you have any electronics experience, remove back, locate power supply (usually has large heat sinks) and c
Aug 21, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Tv turns on but no picture just a red blinking light stays on
Red light blinking means there's a problem in the TV....
What kind of tv is it?
Feb 10, 2009 | Televison & Video
SONY KV-35S26 Blinking picture
Guess I should have looked throught the next couple of posts... The problem you have there you will not be able to repair yourself but a good shop can fix it temporarily. The CRT (Cathode Ray Tube) or picture tube is shorted, that's what is causing your blinking. You can call around and ask a shop locally if they can rejuvenate it for you using a crt analyser. In the shop here we use a BK467 which would fix the problem for awhile. What they will do is take the back off and hook-up the analyser and remove the short temporarily. That fix could last weeks or even months, in most cases though never more than a year. Turn the RV1791 back down, it has nothing to do with the G2 voltage and you don't want to overdrive the crt anyway. Take it back down until the horz. lines disappear in dark scenes or background. Then take it in and have the picture tube rejuvenated. Then start shopping for a new Tv... You'll need one eventually but this will buy you a little more time.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 02, 2008 | Televison & Video
Blinking picture
Do me a favor funstuff send this to my personal email address along with the model number. I get about 3000 emails a day so it's difficult for me to remember what model we are talking about...
Bill
PO Box 442
360-642-4993
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
Sony trinitron tv
If you have sound but no picture it means that your power supply and tuner are working correctly. The number of times the timer LED blinks is the code for the problem with the picture. The computer will stop the picture and blink the timer LED if the vertical circuit stops working, if the picture tube is too weak or if the horizontal sweep has stopped. The set should be serviced by a qualified tech familiar with Sony sets.
Sep 03, 2007 | Sony WEGA KD-34XBR970 34" TV
Sony BRAVIA  KDL-40XBR2 40 in. LCD HDTV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
