Question about Frigidaire GLEQ2152ES Electric Dryer
NO HEAT CAN'T FIND PARTS ANYWHERE
  • 1,998 Answers
You have to take the entire dryer apart on the back wall the hi and the low fuses as well as the heater are under the drum chekc allthree of these parts for continuity with the power off if you need to order parts you can get them from marcone of allbrands appliance hope this helps
Posted on May 01, 2010
How much does it usually cost to get ac fixed 1999 expedition?
Honest that question is impossible to answer. (i will list a few reasons)
1= what shop? $25 hr-or $50hr
2= what is wrong
3= what parts needed
Aug 18, 2015 | 1999 Ford Expedition
Heat disperser (tent) on Brinkmann Patio Grill 810-4010-0 needs replacing.
This is the link to your grill on the Brinkmann Website:
http://www.brinkmann.net/products/details.aspx?item=810-4010-0
This is the link for the manual:
http://images.brinkmann.net/docs/pdf/810-4010-0.pdf
It's usually easier to find parts by the part number rather than the description, because you might call it something other than what the manufacturer calls it. There aren't many parts available as far as I can see.
Dec 27, 2013 | Grilling
Www helmangroup com
http://www.nostalgiaelectrics.com/ This is the current reseller of Nostalgiac electrics.
Unfortunately, they will not help you in any way. Your only action is to throw it away, parts are not available anywhere.
Nov 04, 2013 | Nostalgia Electrics CCP-509 Popcorn Maker
My rear air line as leaks, can I disconnect and just leave front operable?
No, you can't isolate the rear air from the front air, it's all one system. You would have to fix the leak if you want to keep a/c anywhere in your car.
Good Luck!
May 25, 2011 | Air Conditioning and Heat for Ford...
Gas appears to be boiling out of carburator
Hi Judy,
My name is Mike. If you ever see Gas boiling from a carb or anywhere else,
  1. Do nothing that could create spark
  2. Kill the heat source if possible
  3. Clear away, clear out, give it room
One cup of gasoline in vapor or aerosol has the equivalent explosive force of ten sticks of dynamite. Boiling gas is highly volatile and extremely dangerous.
Was there work done to it recently?
Any chance a few parts were omitted during reassembly? Like a heat shield?
Anyway, this is more of a warning than a solution. Don't use it until it's fixed. OK?
Best regards
Aug 14, 2010 | Craftsman Garden
Need a part cannot find anywhere goes behind the lamp on the chassis to direct heat out of set
Try Samsung parts info at 800-634-8276 or 1-800-SAMSUNG cust service. This kind of part is not normally stocked anywhere else.
Apr 14, 2010 | Samsung HL-S5086W 50" HDTV
Where does the ground wire on the starter get grounded
You can bolt the ground wire anywhere to the metal body or frame of the car since the battery is attached to the frame and body all electricity flowing through the body/frame goes to the negative terminal of the battery(ground). Preferably you would bolt it as close as possible to the starter without putting in danger of moving parts or heat though.
Aug 06, 2009 | Honda S2000 Cars & Trucks
I have an copycentre c2o with open heat error is there anything i can do to fix it
Replace the fuser. There is a weird induction heater in the heat roller that blows . Look up "the parts drop" on google. Call Britt and he will give you as good a price as you will receive anywhere.
Its very very easy to change, takes less than 5 minutes if you have no clue what your doing.
Aug 25, 2008 | Xerox Office Equipment & Supplies
Frigidaire GLEQ2152ES Electric Dryer Logo
70 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
