Question about Dirt Devil BRUM M0414 Bagless Vacuum
I assembled my Brum, but it won't charge, and there seems to be no indicator light to be found. What am I doing wrong?
    Sergeant:
    Champion:
  • Dirt Devil Expert
  • 357 Answers
If you just bought it, take it back and exchange it. Some batteries are bad from the beggining
Posted on May 01, 2010
The stick vacuum seems to be charging by the red indicator light turning green, yet will not turn on.
A rechargeable battery will only accept a charge only so many times - it is possible that you've reach that number. Anywhere between couple and a few hundred is about the maximum. Changing the battery will usually solve the problem. Good luck!
Oct 05, 2015 | Vacuums
Neato seems to have died but the green light is on
Mine was doing same thing. was working flipped upside down to replace the rubber blades then nothing.Display dark only it has green led around orange button. Unplugging batteries didn't help.pressing buttons nothing. holding buttons down nothing. Found this on another site. Connect the vac to your computer and place it on charger at same time. Press and hold the orange button for about 10 sec. or so. it should turn of the LED then let up and repress button. vac should then reboot. Unplug computer. Wouldn't hurt at this time to tell it you put in "New Batteries" but first remove any scheduled cleaning days to clear its memory. After doing the New battery, reset the schedule and let it charge. After that it maybe a good time to check your program version and update it from the Neato web site to the newest update. The newest update does wonders for the battery run time issues.
Feb 07, 2014 | Neato XV11 Vacuum
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
My handheld dyson won't charge but when I hold the trigger the lights come on?
Hi Lynora,
I am sorry to hear you are having difficulty with your DC16. Based on the details you provided we would appreciate the opportunity to trouble shoot with you over the phone to determine the best solution.
Please call us at 1-866-693-9766 US or 0800 298 0298 UK. We look forward to speaking with you.
Best wishes,
Jessica
May 03, 2012 | Dyson DC16 Root 6 Bagless Handheld...
When I push the power button on my dc16 animal nothing turns on but a little red light by the red switch.
Hey Josh. According to the manual I found at this URL:
http://media.dyson.com/downloads/us/floorcare/manuals/dc16_opmanual_usa.pdf
the red light that comes on when you try to use the unit indicates that the battery is fully discharged. When you plug the unit in to charge it, the same red light should be blinking to indicate the battery is in the process of charging.
Take a look at this and let me know if you are still having issues with the unit running, as there might be a problem with the wiring from the battery to the motor.
Paul
Sep 18, 2010 | Dyson DC16 Animal Bagless Handheld...
The unit is charged, the charge indicator light is green, and the three lights on the top are lighted and steady but nothing happens. What am I doing wrong?
Press each cycle button and see if it starts up. I don't know if this is new and you just got it, but if so, you may need to remove any straps and retainers blocking the brushes etc.
Feb 17, 2010 | iRobot 4150 Roomba Vacuum
Black and Decker Hand Vacuum (CHV 9600); mike Mills
If it seems to be taking a charge, then the charger and the battries are ok and the problem is with the indicator light. So if it is working normally, I wouldn't worry about that light.
Jan 02, 2008 | Vacuums
Dirt Devil BRUM M0414 Bagless Vacuum Logo
53 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
