Question about Casio FX-9860G Graphic Calculator
Casio fx-9860G graphics calculater, vertical line segment
For a Casio fx-98060G graphics calculator, I want to create an x=c function with a domain, so that it creates a VERTICAL line segment. Everytime i do the standard domain setting, it comes up with Syntax error.
  • Casio Master
  • 7,993 Answers
I am not sure how you can create such function (the range limitation do not work for x=c) but you can draw a vertical segment, just do not call it a function.
Draw a graph Y1=0
Then press SKETCH function key and use the F6 key to cycle through the TABS at the bottom of the screen. Look for the TAB named PEN. and click the function key below it.
Use the arrows to move the cursor to a spot on the screen (near the bottom), Press EXE to fix the starting point of the segment. Then use the Up arrow to draw a vertical segment from bottom to top.
Posted on Jul 25, 2010
Memory error instruments
Exactly what were you trying to do? It helps to understand the problem you are having. Usually it means that the result exceeds the capacity of the memory (Too big). The upper limit for the calculator is 9.9999999.. *10^(99) or 10^100.
Nov 14, 2013 | Casio FX-9860G Graphic Calculator
Can you calculate indefinite integrals on the casio fx-9860G
Unfortunately, the Casio FX-9860 G does not have a Computer Algebra System or CAS. For this reason it can only calculate definte integral over a given interval. The lower and upper limits must be supplied. The result will be a number.
Casio calculators that have a CAS are the Casio ClassPad CP330/ 300Plus/ 330, or the Algebra FX 2.0.
Feb 08, 2012 | Casio FX-9860G Graphic Calculator
Prime factorization using Casio FX-9860G Graphic Calculator
There is a program called Prime Factor Analysis on this site. It is written for the FX-9750GPlus calculator but I suspect you should be able to use it on the FX-9860G. To access the site you must have an account. You can register and it is free.
Jul 30, 2011 | Casio FX-9860G Graphic Calculator
How to do the log to the base e question with calculater casio fx-9860G
The log to the base e is the so-called natural log, denoted ln. Look at the screen capture below. The relevant key is at the bottom of the picture. Look also at the screen for syntax of the command.
Jun 07, 2011 | Casio FX-9860G Graphic Calculator
How can you change the mode on a casio fx-9860g calculator to deg. mode?
Press SHIFT MENU to bring up the setup screen. Use the arrow keys to move to the "Angle" line and press the function key for the desired angle mode.
Mar 04, 2011 | Casio FX-9860G Slim Graphic Calculator
With a Casio fx-9860 G II, how can you change the log base to somthing other than 10?
You can calculate the log to any base using the logab function in the MATH menu.
Feb 08, 2011 | Casio FX-9860G Graphic Calculator
I have the Casio FX-9860G Slim, how do i do logs with something other then base 10?
Use the logab function in the catalog. For example, to calculate log base 2 of 32:
OPTN F4 F6 F4 2 , 3 2 ) EXE
Dec 15, 2010 | Casio FX-9860G Graphic Calculator
How to find the cube root?
Use the cube-root function. It's the shifted function of the ^ key.
The use of that key may depend on whether you're in Math or Line mode. Refer to page 2-4-7 of the manual for more details.
Nov 13, 2010 | Casio FX-9860G Graphic Calculator
My casio fx-9860G au, wont copy equations from statistic mode to graphic mode. can you please tell me how i can fix this?
Just in case you did not find the Copy function I am including this screen capture from the FX-9860G SD.
The function is available at the bottom of the screen that displays the regression curve. Press Copy and select a function Y1= or Y2=. The next time you press the Draw tab the scatter plot and the regression curve will be displayed on the same screen.
Aug 15, 2010 | Casio FX-9860G Graphic Calculator
Installed a wrong OS update version
get battery out-and install it again(after you return the battery)
Jun 27, 2008 | Casio FX-9860G Graphic Calculator
Casio FX-9860G Graphic Calculator Logo
345 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
