Question about KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble Front-Load Washer
What does Troubleshooting "F" "02" mean - KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble Front-Load Washer
  • 1,998 Answers
F02 Long drain If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.hope this helps
Posted on May 01, 2010
What are 02 and 05 error codes?
Consult the owner's manual troubleshooting section. If not there, search the internet for:
Make + Model + the words "error code 02" or "05"
Mar 12, 2016 | Singer Futura CE-250
2003 honda civic o2 how to replace And how do i fin out which once is it
Hi Jesus, Im AL the owner of Big As Auto Repair.
If you have a 4 cylinder engine then you will only have two 02 sensors 1/1 is upstream and 1/2 is downstream. Upstream is the one closet to the engine and downstream is the one farther away from the engine.
If you have a six OR eight cylinder engine you will have four 02 Sensors. 1/1 means Bank One Sensor One. 1/1 and Bank one means right bank and right bank means the side with the number 1 spark plug. SO, 1/1 means, "Right Bank" Upstream 02 sensor. 1/2 means, "Right Bank" Downstream 02 sensor.
2/1 means, "Left Bank" Upstream 02 sensor and 2/2 means, "Left Bank" Downstream 02 sensor. Hope this helps and please visit my auto-repair-website at: http://www.bigasautorepair.com/
Nov 26, 2015 | 2003 Honda Civic
What does code P112D mean
02 sensor neg. current or positive current open circuit bank 2 sensor 1
Dec 23, 2014 | Cars & Trucks
P144A and P1296 code on a 2010 Ford Escape
Code p144a 02 sensor circuit high voltage(bank 1 sensor 3
code p1296 multi-faults-bank2-with low side shorts
Nov 09, 2013 | Ford Cars & Trucks
Srs light came on and cut off and didnt crank back up
For SRS light coming up issue problem,check the list of help links provided below.Click the link to go through its procedure :-----How i solved SRS and AIRBAG OFF light problem ? http://technoanswers.blogspot.in/2012/02/how-i-solved-srs-and-airbag-off-light.html----------------
Airbag and srs light off?
http://technoanswers.blogspot.in/2012/02/airbag-and-srs-light-off-on-mercedes-ml.html
---------How to remove SRS airbag? http://technoanswers.blogspot.in/2012/02/how-to-remove-srs-airbag-on-honda.html
---------AND FOR ,
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 29, 2012 | 2000 Mitsubishi Montero Sport
Brake drum
For drum brake related problem,i suggest you to go through this help links.Clickj the link below for troubleshooting procedure:-----How to service Drum brakes? http://repairhelpcenter.blogspot.in/2012/02/how-to-service-drum-brakes.html-------- What type of problems usually noticed on Drum brakes? http://repairhelpcenter.blogspot.in/2012/02/what-type-of-problems-usually-noticed.html--------- How to test Drum Brakes? http://repairhelpcenter.blogspot.in/2012/02/how-to-test-drum-brakes.html
---------How to inspect brake drums? http://repairhelpcenter.blogspot.in/2012/02/how-to-inspect-brake-drums.html
---------This will help.Thanks.
Feb 11, 2012 | 1991 Honda Accord
My 2000 x5 4.4 bmw is constantly losing power due to battery drainage. The light by the shift stay on when i turn the car off, do this mean my car is not going in sleep mode.
This will help.
Thanks.
Jan 31, 2012 | 2000 BMW 5 Series
What tools are required to change drum brakes on 2005 sunfire
For drum brake related problem,i suggest you to go through this help links.Clickj the link below for troubleshooting procedure:-----How to service Drum brakes?http://repairhelpcenter.blogspot.in/2012/02/how-to-service-drum-brakes.html--------What type of problems usually noticed on Drum brakes?http://repairhelpcenter.blogspot.in/2012/02/what-type-of-problems-usually-noticed.html---------How to test Drum Brakes?http://repairhelpcenter.blogspot.in/2012/02/how-to-test-drum-brakes.html
---------How to inspect brake drums?http://repairhelpcenter.blogspot.in/2012/02/how-to-inspect-brake-drums.html
Jan 23, 2012 | 2005 Pontiac Sunfire
How to change the brake drums
Jan 23, 2012 | 1994 Hyundai Excel
Washing Machines Logo
156 people viewed this question
Top KitchenAid Washing Machines Experts
Sal De
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
