Question about Salton Scooby-Doo Popcorn Maker
Stopped working . We popped a batch of popcorn and waited 10 min to do another. When plugging in machine it does not work!
I'm on level 15 how do i start over on level one
Um, clean the popped popcorn out of the popcorn machine, and start with a fresh batch?
I know this doesn't help much, but it also has nothing to do with popcorn machines.
Oct 23, 2013 | Kitchen Appliances - Others
Model 39A gets too hot too fast
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly.
The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast.
The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot.
A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn.
Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
May 20, 2013 | Star 39 JetStar Popcorn Maker
I have 2003 model whiz bang popcorn machine that takes forever to pop the corn
Old popcorn is the first thing to check, and that you are measuring correctly. 12oz of popcorn is the correct amount in a 3 min popping cycle. always time the 2nd batch.
That model popper has 2 heat elements, and 2 thermo stats that control them. If the first 2 things to check are good, then you dropped a thermo stat or heater and it is operating on 1 heater instead of 2.
Jan 21, 2013 | Gold Medal 2003 Whiz Bang Popcorn Maker
My Beaumark popcorn maker isn't working! I have the type that is a large domed electric pan, with a metal 'stick' that goes around to move the kernels (presumably to stop them from sticking?)....
your problem is in the instructions.. you need to make it a little hot, means run it on empty for a few min. stop the machine, and add 2 tablespoosn of veg. oil your fav. oil, not olive. add enough pop corn to fill the inner circle surface of the bottem plate, then run it again until the bowl is full.. maybe 5 min. You should have perfect bowl full of pop corn.
enjoy :-)
Sep 15, 2011 | Vacuums
Doesn't heat
The heating element has burnt out or is defective! return for repair or if you have recipt a new one!
Jan 25, 2009 | Cuisinart CPM-900 Popcorn Maker
Pop corn doesn't pop
stupid
your not supposed to put it in the refrigerator!
Jan 22, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
Galaxy popper g12 unpopped kernels
The problem you are having is the thermostat inside the kettle is getting weak these can be ordered from Star Manufacturing or a concessions supply place that does repairs Also Gold Medal Product has a similar thermostat that will work in your kettle pt# 47082 Just a FYI
Jan 13, 2009 | Galaxy G18-AT Popcorn Maker
Can't make multiple batches of popcorn
We are under new management.
Please contact us at 1-920-347-9122 and we can help you with your Nostalgia Electrics product.
Also, please visit our new website at www.nostalgiaelectrics.com
We are more than happy to assist you.
Jan 11, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
Salton Scooby-Doo Popcorn Maker Logo
Top Salton Kitchen Appliances - Others Experts
Gareth Cockram
Gareth Cockram
Jerry Greenberg
Jerry Greenberg
Robert Plante
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
