My HP Photosmart just will not print. The printer shows up in the printer windows and I've uninstalled and reinstalled too many times to count. Finally, I think I found the problem. amidst with with all the complicated stuff, I didn't look under the "hood." When I did, I found that the color cartridge had jumped out of its slot and there was ink all over the place. I cleaned it up the best I could, but I once heard that if cartridge ink gets into the printer, the printer won't work. Is that true?
  • Beverly H May 01, 2010
    All went well after cleaning the cartridges and finally the printer did print a test page.
  • 2,427 Answers
Well that depends on who attempts to fix it.. the reason people say it doesnt work is cause they didnt clean it off properly.. see the part where the ink tank circuits meets the ink well contacts,, ensure you clean that propperly and replace the ink well.. That should fix it..
Posted on May 01, 2010
  • 4,924 Answers
It should not be ...its true that the ink is corosive and radioactive (if it is toner -black ) and it can make permanent damages if let there for a long time ...to dry itself...but if you clean it really well and wit care and patience ..and the printer has nothing stuck or permanently physically damaged... it should work with no problems ...so be careful ...see that you clean all well...if the cartridges are damaged..get new ones (preferably original ..and try to get not chipped so you will be able to refill them without recognition problems) and it will work ..I say that from my own experience ...I have a small family bossiness with printing and xerox machines ..and each time I mess one up real good..I spend some time cleaning it ..but if all parts are ok ..and in place ..they always work ...
  • Catalin Turcu
    Catalin Turcu May 02, 2010
    uyeah ..if they do not have permanent damages..a good cleaning will make it functional again ..I told you in the first comment ..the issue is hat cause it was so messed up ..it might give you stripes on printings for a while..until it will clean itself perfect ..
My printer will not print...it's saying it's not installed but showing that it is...has worked fine for a year or so but now won't print...I have unistalled and reinstalled the software but it's still the...
Go to Control Pannel and Add remove Programs
and
Uninstall the HP Photosmart 8250 Inkjet Printer Drivers
or
Click start - control pannel - System - Hardware - Device manager - Select the Printer (+) and uninstall the Drivers
then Check by connecting the USB Cable to the Computer without installing the drivers
IF its NOT SHOWING " Found New Hardware Message " - then Please make sure the Printer is on / check replacing the USB Cable - the install the Drivers
If it should show the Found New Hardware Message - then we can deside to install the drivers for the Product
Then download the Updated drivers from HP Photosmart 8250
if above link don't work then
chek : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=443024&lc=en&cc=us&dlc=en&lang=en&cc=us
According to the Operating System ..
Jan 06, 2010 | HP Photosmart 8250 InkJet Printer
When I install the D7260 printer using the CD-Rom supplied it works fine. Then after a few days only the top two or three lines of the first page are printed and, after a long pause, the sheet comes out....
Many issues are caused when the HP Photosmart is connected to computer using a USB cable before the HP Photosmart software is installed on the computer. IF you connected the HP Photo smart to your computer before the software installation screen prompts you to do so, you must follow these steps.
Troubleshooting common setup issues :
1) Discoonect the USB cable from the computer.
2) Uninstall the software (if you have already installed it.)
3) Restart you computer.
4) Turn off the HP Photosmartm wait one minute then turn it on.
5) Reinstall the HP Photosmart software.
If your installation is incomplete, or if you connected the USB cable to the computer before prompted by the software installation screen, you might need to uninstall and reinstall the software. Do not simply delete the Hp Photosmart application files from your computer. Make sure to remove them properly using the uninstall utility provided when you installed the software that came with the HP Photosmart.
To uninstall from a Window computer and then reinstall
1) On the Windows taskbar, click Start, Settings, Control Panel (or just Control Panel).
2) Double-click Add/Remove Programs (or click Uninstall a program).
3) Select HP Photosmart Driver Software, and then click Change/ Remove.
Follow the onscreen instructions.
4) Disconnect the HP Photosmart from your computer.
5) Restart your computer.
Note : It is important to that you disconnect the HP Photosmart before restaring your computer. Do not connect the HP Photosmart to your computer untill after you have reinstalled the software.
6) Insert the HP Photosmart CD-ROM into your computer's CD-ROM drive and then start the Setup program,
7) Follow the onscreen instructions and the instructions provided in the Setup Guide that came with the HP Photosmart.
Nov 09, 2009 | HP Photosmart D7260 Printer
HP Photosmart C7200 All-in-One Series is always going offline and then won't print-I am using it with my wireless computer. When I ask it to fix it, it now just says it's disconnected and that print job...
I request you to follow the below web links to resolve the issue:
Weblink1:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01886205&cc=us&lc=en&dlc=en&product=3204785
The above web link for windows 7 but you can perform this any of the windows operating system
Weblink 2:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01084690&cc=us&lc=en&dlc=en&product=3204785
Weblink 3:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01548600&cc=us&lc=en&dlc=en&product=3204785
Oct 12, 2009 | HP Photosmart C7180 All-In-One InkJet...
Printer will only print, not copy fax or scan
It is possiblethat the all in one solution software you used in XP doesn't work with Vista, after some update or other. You did the right thing by uninstalling and reinstalling. Make sure you have the correct driver from the HP site..
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP C6180) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
Will not print
dirver conflict, completely remove from OS, take off network and see if HP works independently well. reset on network and share again.
Jun 22, 2008 | HP Photosmart C7280 Printer
Unable to access HP Photosmart
u change ur printer its simple
Dec 10, 2007 | Office Equipment & Supplies
19 people viewed this question
k24674
jasbo
jasbo
