Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
My hard drive only works on some computers
Ok so my hard drive is able to connect to my one computer fine which is running vista and i am able to move and transfer files but if i hook it up 2 my laptop with xp it recognizes that i pluged something in but does not show up on the computer screen, i right clicked on computer and went to manage and found it their but it did not have ntfs or whatever it is so i went back 2 my desktop and formated it for ntfs or whatever and it still wont work how can i make it so my laptop which bypasses the requirements work!?!?
    Scholar:
  • 103 Answers
U need to reinstall windows on ntfs file system
ie the system files drive should be under ntfs and not fat32
try this and let me know incase any issues
Posted on May 01, 2010
Changed computers and windows vista doesn't want to open our external hard drive
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Feb 01, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
< problem identifing Sea-gate external hard drive (500 gb- no external power) > my extrenal hard drive has a odd problem : sometimes when it got connected to the vista laptop its light turn on &...
then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Aug 10, 2010 | Seagate FreeAgent Go 500 GB USB 20 Hard...
My Portable hard drive will only work on 1 computer
then check.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Jun 03, 2010 | LaCie Computers & Internet
It was working fine with Windows Vista. Then I
please check ur harddrive where it plugged with ur motherboard..... it's in master or slave... or put it in to master
Nov 15, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Startup Problem with Lenovo 3000 N200 with Vista
You would need to reinstall Vista together with the device drivers and programs to get a laptop functioning again.
You need to backup your data before you reinstall Vista but since you cannot boot up and get into Windows, you need to remove the hard drive and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. This computer should see this hard drive as an external hard drive (provided the hard drive is OK). You can now see the various folders and files, copy your data files to a USB memory stick or burn them to a CD.
Insert the hard drive back into your laptop and then install Vista.
Jun 15, 2009 | Lenovo 3000 N200 PC Notebook
Drive Being Recognized as Removable Disk
Use EASEUS Data Recovery Wizard to recover the data. You can find the program on the internet..
To format afterwards click Start, click Run and type compmgmt.msc.. In there format your drive..
Mar 10, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
External drive not showing up at all
i was working with (easy hard lock) and than i lock my external hard drive
now i cant get access to my external hard drive
(the program said dont lock external hard drive but i did i didnt know that )
can someone help me please
thanks
Jan 21, 2009 | Western Digital My Book Essential Edition...
Hp nx9110 laptop
There are several ways you can check if you have a working hard drive in your laptop.
1. Get into the BIOS configuration of your laptop, you may be able to see your laptop's configuration, and maybe even see your hard disk. This means your computer has been configured to work with the hard disk, but does not mean the hard disk is OK
2. If your laptop has a floppy disk attached then you can use a boot floppy disk and boot up in DOS. Then you can then run FDISK and then display the hard disk. If FDISK does not detect a hard disk the it is most likely dead.
3. If you can get access to a USB hard drive adapter cable or an IDE adapter cable that you can connect to a working computer's secondary IDE controller. THEN
Remove your laptop drive and connect and connect it to the USB adaptor or an IDE cable, (make sure you connect the drive correctly to the connector) then connect it to a working computer.
If you use an USB adapter, when you connect it to a working compute with XP or Vista operating system, and if the hard drive is OK then you will see the contents of the laptop hard drive.
If you connect the IDE cable to the secondary contriller and then boot up the working computer with XP or Vista operating system, if the laptop drive is OK you should see the contents of the laptop hard drive.
If you don't see the hard drive, then most likelt it is dead.
Jul 27, 2008 | HP Compaq Business NX9110 Notebook
PATA hd slave to SATA hd
Please one hard drive main disk and second one is slave so like this please remove the jumper for second one so first one is having the vista os (SATA) your computer will run normaly then attach the seond hard drive as slave (remove juper drive) you can see the dat (PATA)
Jul 18, 2008 | Computers & Internet
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
107 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
