Question about Dimplex DS5598 Mid-Size Heater
The realistic flame has gone out. I only see one white bulb just inside the door at the top and it is on. Are there any other bulbs ???
  • 10,865 Answers
Hello. It sounds like a problem with the flame motor.
I've attached a link to the manufacturer's website. They may be able to assist you with additional information upon request.
http://www1.dimplex.com/technical.aspx
Let us know if this was helpful
Posted on May 01, 2010
  • scottrochny
    scottrochny Jan 12, 2012
    The flicker motor is worn out.
    $90 shipped to USA from Dimplex in Canada.
    Ask for the DPF service manual.
The inside light bulb that works when the door opens and food is cooking is burned out, I have the new bulb but don't know where to replace it.
Brand and model would help but I'll guess at this. If micro is a wall hung unit over the range, you usually need to remove the top grill assembly above the door. Then look inside directly above the area where the bulb is located. You should see a metal cover with usually 1 screw in it to remove. Once screw is out that metal plate usually pulls forward and upward to reveal the bulb and socket. Replace bulb and reverse procedure to assemble.
If the micro is a counter top model---the complete outer case usually needs removed if you don't see a small access door by the bulb. Remove all screws around back edge and any screws in the side panels---then lift back edge and pull outer case rearward to remove.
Jun 03, 2015 | Microwave Ovens
GE side by side refrigerator main light bulb stays on even when door is shut firmly.
There is a switch just inside the door in most on the roof of the fridge, make sure it is not damaged.
Jul 02, 2017 | Refrigerators
Bulb replacement
Dimplex uses common bulb types. Either incandescent or halogen. Consult your owner's manual for bulb type and wattage, then visit your local hardware or convenience store. It should be easy to find. If you lost your manual, simply remove the old bulb and bring with you to the store.
Feb 04, 2013 | Dimplex CS3311 Compact Heater
How do i change the bulb
Bulb TVs are very big. In most cases the TV will give a warning that alerts you it's time to change the bulb. Do not touch the glass part of the bulb, as oil from your hands will reduce the life span of your bulb. Replacing the bulb is a simple process that will take a few minutes. Here is how to do it.
Step 1: Read User Manual Make sure that you have your user manual with you when working on your TV. Most electrical appliances will have guides on how to deal with replacements of parts and where to get the replacements and what specifications to look for. Read the user manual in depth before attempting the project of replacing the bulb. Step 2: Disconnect Power When working with any electrical appliance, always switch off and disconnect the power. Electrical shocks can cause injury or even death. Step 3: Open Bulb Door At the back of the TV there will be a bulb door which will usually be near the power cord, depending on the make of the TV. Once you locate the door, proceed to open either by sliding it open or unscrewing it as may be required. Step 4: Remove and Replace Bulb Once the door is open, unscrew the bulb assembly and remove it. You can then remove the bulb from its compartment. Bring out the new bulb. Hold up the groove on top of the new bulb and align with the groove pocket on the inside of the TV, then proceed to slide the new bulb into place. Step 5: Replace Bulb Assembly Once the bulb is securely held in place, return the bulb assembly to its position and screw it back. Make sure not to tighten it too much but have the screws just firmly in place. Step 6: Close Bulb Door Once you are finished, you can close the bulb door after making sure there are no tools or screws left inside. Having such items inside the TV could cause a short circuit. Your door needs to be closed for the TV to operate. Tips: Remember to allow the old bulb to cool before you remove it. It will usually heat up to very high temperatures that could cause some serious damage. Most TV bulbs will warn you to replace your bulb while about a hundred hours are left on the old bulb. This duration is meant to give you time to get the replacement bulb and fit it. Finally, if you do not feel confident in doing the replacement yourself, get a professional to do it for you. They might charge you a fee, but it will be cheaper than the cost of damage caused by a poor fit.
Take care in solving the fault
May 12, 2011 | Zenith R57W46 57" Rear Projection...
I cannot get the lite inside the refrigerator to lite, have tried new bulbs, no luck
bulbs need to be supertight to make connection,almost too tight....keep turning till it comes on-it will.
Mar 10, 2010 | Refrigerators
Interior Microwave doesnt come on..Burned out?
If it doesn't have a door you have to remove the cover. Its likely a special microwave bulb and the socket will have to be replaced with the bulb. the bulb is built onto the socket.
Jan 14, 2009 | Sharp R-1514 Microwave Oven
Mod #GD5RHAXNQOO
Possible that the door switch is the reason.Check for powerat the door switch
May 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Dimplex DS5598 Mid-Size Heater Logo
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
