Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Mower dosen't run when engaged
My mower starts and runs when dis engaged in the back but when you engage the mower it won't start.
  • 29 Answers
The pto switch is also a safety switch, be sure it is disengaged
Posted on May 01, 2010
I have a john deere 345 tractor starts fine but bogs down after I engage the mower and wont stay running
Although not a riding mower, when mine was doing that, dis-assembled, cleaned and then re-assembled the carburetor. Now doesn't shut off when engaging the mower. Also, if you left gas in the mower over the winter, try some of the additive, but that didn't work for mine.
Jun 14, 2014 | John Deere 420,1020,2010,2020,2510,2520...
How do i dis engage the safety device?
It's not recommended but find the switch you want to bypass should have two wires going all the switch does is make a connection to send the power to start the mower or to keep the circuit going to keep mower running
Jun 13, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Only starts if mower lever engaged (without drive belt)
Sounds very strange but i would guess either a micro switch or one of the relays behind the dash.
Dec 16, 2017 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses...
HI jLAFORCE 1.
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
https://www.briggsandstratton.com/eu/en.../top-5-mower-troubleshooting-tips.html
Lawn mower won start Google Search
Nov 30, 2017 | Simplicity Vacuums
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
When engaging the moer it doesnt want to start
The tractor has a safety feature that doesn't allow you to start the engine with the mower engaged. Just disengage the mower, then start the engine. Once you have it running, then engage the mower.
May 21, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
129 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
