Question about Intel Motherboard
The H55M-UD2H MOTHER BOADR STARTS TO BOOT THEN POWERS DOWN IM SHURE THE WIRING IS COCECT THANKS
  • nikulay May 11, 2010
    does the Processor Fan is running when you turn on the computer?
    Novelist:
  • 138 Answers
Hello
This board has 2 slots for the ATI Crossfire video cards. Since the computer is turning off right away, it would appear that your PSU (power supply unit) does not have enough watts to power the motherboard and Crossfire video cards.
Check with ATI for the power requirements for your video cards and upgrade your PSU.
I typically see SLI / Crossfire systems with at least a 800 watt power supply. If you are below this, you will need to upgrade your power supply.
If you have a larger power supply, you will need to verify it is working correctly.
Posted on May 01, 2010
Unit starts/stops-starts/stops after replacing 3v battery?
When you say starts/stops (etc) are you saying it just keeps trying to reboot? Or are you getting a message such as boot disk not found press any key to restart? Replacing the 3V battery will cause the CMOS to reset to factory defaults. You may need to go into the CMOS and make setting changes to point to the proper disk drive for booting. You may even have to change the type of disc drive since there is now the old MBR as well as the newer GPT format. Also, there is the possibility that if you are upgrading you may need to use the legacy CMOS instead of the UEFI that many newer mainboards come defaulted to. Any error in the CMOS settings can cause a boot failure.
Apr 03, 2016 | Gigabyte GA-H55M-USB3 Socket 1156/ Intel...
1 LONG BEEP, 2 SHORT BEEP
1 long, 2 short Failure in video system: a checksum error was encountered in video BIOS ROM, or a horizontal retrace failure has been encountered
Apr 29, 2014 | Gigabyte Motherboard GA-H55M-UD2H Core...
1 long beep, 2 short beep
You have a bad RAM, install just 1 module and try, is doesn't swap the memory module and try again.
http://www.gigabyte.com/support-downloads/faq-page.aspx?fid=816
How to reset BIOS on Gigabyte GA-H55M-UD2H. Here's my story. A long while ago, I set a password to my BIOS. But then almost 11 months later, trying to use it, I can't remember the password. Is...
check your motherboard manual fo CMOS reset jumper location on you motherboard, and follow the instructions on resetting to defaults. Keep in mind that any customisations implemented by you in bios will be lost, so you will need to do them again.
Hope that helps
Cheers from NZ
Jun 19, 2011 | Gigabyte Computers & Internet
My motherboard is asrock h55m-le it is showing some problem.. on starting windows.. my windows sign hangs on startup.. please advice me what to do.. i think it is over heating problem..
where your screen hangs....
1 if using XP did it hangs when xp is bootig??
or any other time.
and if yes then it is not mother board problem ...rather it is a hard disk problem.
you will have to zero fill your hard disk.\
if helped ..please thum up
Jan 09, 2011 | Asrock H55M-LE LGA1156/ Intel H55/ DDR3/...
D101GGC MOTHER BOARD SUPORT VISTA
all mother boadr support but they will perform differently as per their capability .as per your case it will suppoert but the pc will run very slowly.its better u use Xp instead
Jan 28, 2010 | Intel D101GGC Motherboard
EMachines t3626 shuts down at random
You may be dealing with bad or overheating with your processor or memory. If possible, try swapping out your memory chips to see if that does the trick. If not, you will have to try swapping out the processor (much less likely you'll be able to swing that).
Jul 28, 2009 | E-Machines eMachines Desktop PC
Intel Motherboard Logo
117 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
