Question about Sanyo Vpc-s1070w Digital Camera
0x13010020 lens error is what its saying and then shutting itself off. whats wrong
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Jan 25, 2011
My camera is canon ixus 105.i cannot turn it on.the lens is not coming out.its says "lens error will shut down automatically Restart camera".what should i do.?thanks
something has malfunctioned in the lens motor itself, unfortunately this means that your going to have to take the camera into a repair shop or send it back to canon for repair.
May 05, 2011 | Canon PowerShot SD1300 IS IXUS 105...
My camera will turn on then shut off a few seconds after even if it has been charging for an hour whats wrong?
Most likely the lens is jammed or stuck. The unit is trying to initialize, and not being able to, shutting itself down. Dust and sand can work it's way into the lens assembly, and jam the gears. You can try to spray it out with compressed air to try and free it up. If that doesn't work, here's some things you can try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The page is for lens errors, but it applies to your problem.
They say about 50% of the cameras with a lens error/shutdown problem can be fixed.
Good luck, thanks for using FixYa, and hope this helps.
Aug 20, 2010 | Samsung L200 Digital Camera
Nikon COOLPIX L18 Digital says lens error!
Sometimes the lens is just stuck, sometimes it needs to be replaced. Try to mechanically move the lens in and out by gently twisting, pushing and pulling. If that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Apr 19, 2010 | Nikon COOLPIX L18 Digital Camera
My Kodak EasyShare C813 says lens error 111000 evrytime I turn it on. And then it will shut itself off. What is wrong with my camera?
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 31, 2009 | Kodak Easyshare C813 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Turn the camera on, getting a error flashing it says FEE, what could it be?
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
Jul 10, 2009 | Nikon N60 35mm SLR Camera
Lens wont close properly
hi...
thank u rate me!!!
Jun 01, 2009 | Sanyo Cameras
Lens Error!
thank u rate me as fixya!!!
May 28, 2009 | Nikon COOLPIX L10 Digital Camera
Lens will not close
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Nov 11, 2007 | Canon PowerShot SD850 IS Digital Camera
Lens error 111.000 and 221.000
Sep 23, 2007 | Kodak EasyShare C743 Digital Camera
Sanyo Vpc-s1070w Digital Camera Logo
176 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
