Question about Mitsubishi WS-65809 65" Rear Projection Television
Redish Pink screen??
Slinte,
Can you please tell me where I can find the red circuit drive and where I can locate the resister switch. I'm not sure where those are. Last night I took off the front speakers and tried to adjust the 3 nobs in the front labeled RGB, but that didn't do much. I seems like everything that is white is showing up red. Also, it seems like the left side of the screen is more red than the right but I could just be seeing things - after you look at the tv for too long you start to think that it looks better but in comparison to another small tv that I have the color is still very pink. If you could give me an idea on where I can find the two things you mentioned trying I would greatly appreciate it. Also when you say if it's not one of those two things and that it is probably the CRT, what exactly does that mean. Sorry I don't know too much about TV's or how to fix them - thank you very much.
Your set doesnt have a color wheel you have 3 CRTs instead. Try turning down the red drive on the red crt circuit board that should help if not check the resistor that is connected to the red drive switch Vasriable resistor(switch) that is probably open if not the crt is probably at fault. If you need more info let me know
  • Mitsubishi Master
  • 8,617 Answers
The CRT is the picture tube. If you cant control the red alot of times its the picture tube (CRT) that has shorted causing the screen to take on the dominant color of the affected tube.
Posted on Mar 25, 2008
How to repair a TcL CRT Televission
• Redish problem can be attributed to a weak CRT, or bad Red Video
Drive Circuits.
• Take a look at the Board with CRT socket and inspect for
possible cold solder joints on the Red Drive Transistor and associated
components.
• here are some of my tips:
Flyback Transformer
let me know if you need further assistance!
Sep 09, 2012 | Televison & Video
Jvc hd projection tv screen is tinted pink/red PLEASE HELP!!
not so sure if warped lines about it not being convergence, if the lines are diagonal and light red etc it may be a screen circuit issue. Hard to tell from description----take a few good photos and post them on a free photo sharing site and provide a link here---expert who sees what it looks like may be able to help...............
Sep 02, 2012 | JVC Televison & Video
Cannot use the 5 push-bars on X7G-NagaV to reduce the pink (red in) the background. Do you have instructions for which button to push & the sequence? Thanks
Please check to make sure that the pins on both ends of the VGA cable are OK and seted properly on bothe ends.
There is no adjustment for color casting on the screen (redish, greenish, or bluish cast).
You may have problem in the monitor or the video card.
http://s807.photobucket.com/home/budm/allalbums
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
May 09, 2010 | Sceptre X7G-Naga 17" LCD Monitor
Hitachi 50v500 LCD, at the center of the screen there is a lighter spot than the rest of the screen,about a 10 inch diameter circle. Is this a bulb problem.
If it is a redish oval it is not the bulb. Go to a black and white program and take a good look.
If it is the red or pink oval let me know and I will tell you what the problem is.
If this helps you rate this solution as I do this here for free.
SD TECH
Jan 09, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Pinkish Red Screen??
the RGB controls that you found were those the focus or were they the screens? There should be small switches like that (variable resistors) on the CRT circuit boards themselves. The crt circuits are attached to the crts end . You can gain access to them by removing the speaker grille and access panel in front. I am not sure of the resistors number for that model, however these are always brown resistors and and you will see that one leg is attached to the runner right next to that control switch. I will try to locate the service info for that cahssis V18 and repost if I can locate the info.
Mar 25, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Pinkish red screen
Your set doesnt have a color wheel you have 3 CRTs instead. Try turning down the red drive on the red crt circuit board that should help if not check the resistor that is connected to the red drive switch Vasriable resistor(switch) that is probably open if not the crt is probably at fault. If you need more info let me know.
Mar 24, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Pink vertical line on the screan
Hello pse try to connect an ordinary screen to your computer and see if you have the same problem then...use both screens at the same time ...and see if your lcd is the same or not...please tell me how it went...good luck...be hearing from you...Ron
Feb 27, 2008 | Compaq Presario M2000 Notebook
Colour issues
Sounds like your red gun may be shorted, Try adjusting the red gun down a little see it that helps.You can also switch the blur CRT socket for the red if your screen is still mostly pink then you know for sure its your red tube that needs replacement. If its mostly blue then you have a problem in the red drive circuit.
Jan 14, 2008 | Televison & Video
Sony TV 27" KV-27V36
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician. i cannot tell you the cost to fix your tv coz my location is in the Philippines.
Jan 18, 2007 | Sony KV-27V36 27" TV
Mitsubishi WS-65809 65" Rear Projection Television Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
