Question about Microsoft Wireless Optical Desktop Comfort Edition
The @ sign on my keyboard won't work!!!
When trying to type the @ sign into an email address or word document, the only character that appears is the ' sign. I am having to copy and paste the @ sign from the internet as I am unable to type it. Any suggestions?
  • Anonymous May 01, 2008
    The
  • 807 Answers
Go to control panel on start menu.You may have to click Classic View. Click Regional and Language options. Click middle tab at the top called Languages. Click the Details button. Click Add and select the English UK option from the drop down list. Apply and Ok.
Posted on Mar 25, 2008
3 Suggested Answers
SOURCE:
StuartB
  • 807 Answers
SOURCE: The @ sign on my keyboard won't work!
  • 905 Answers
SOURCE: Keyboard problem
you may need a new battery in the keyboard, also if it is dirty on the IR sensors you will have problems
Posted on Oct 09, 2008
My email n password dont match, how can I fix it?
The procedure to troubleshoot email account login issues may vary depending upon your email service provider. So, to let us suggest you a specific solution, can you please share with us the name of your email service provider?
In the meanwhile, we recommend you to make sure that all the keys on your keyboard are functioning properly. If one or more keys are jammed or have stuck up, the keys that you hit may not display characters correctly on your login page. Also, make sure that the functional keys like Caps Lock and Nums Lock are On or Off only when required. To make sure that the keys on your keyboard are working fine, you can first try typing your email ID and password on a Notepad or Word Document and see if they come up correctly. If the keyboard is working fine, we suggest you to try typing your email ID and password slowly (if you have not done this already). Also, give special attention to characters like 2 or Z, 0 (zero) or O, 1 or I, 5 or S, 8 or B etc.
If one or more keys on the keyboard have become malfunctional, try logging in to your account through some other device (if you have not done this already) or consider using a different keyboard (if possible).
You can also try onscreen keyboard by press and hold the Windows key and hit the letter R. Type in OSK and hit enter. Try using the onscreen keyboard if the keyboard is not functioning correctly.
GuruAid.com
Jul 17, 2014 | Computers & Internet
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
Keyboard not functioning
It may be a fault in the keyboard driver or in the keyboard itself. However if the character you need is not available on the keyboard directly it is possible to get any character by using the ASCII char code entry method. First off search the internet for a ASCII character number associating table (for a chart I like best, check here http://michaelgoerz.net/blog/2008/09/ascii-table/ascii.gif) now on this chart you have to use common fonts (IE: Ariel, times new roman, ect.) because some of the TTF fonts do not have all the characters in them available.
Now to practice using the characters, load Notepad and find the character you want to display from the chart (note: the number like 000d and 00h actually means 000 decimal and 00 hexadecimal, only use the number with the "d" after it with this method), on Notepad, after you pick out the character you want to display, press and hold the ALT key, and on your keypad (on most keyboards it is on the right side and resembles a calculator type keypad) while holding the ALT key down enter the number of the character you want to display (do not include the "d", only the number) then release the ALT key and that character should display for you in Notepad. Almost all standard fonts has the regular characters and some has the extended characters, you will have to check to see if the font uses them by trial and error. this method is a long lost forgotten means of putting characters into your documents which does not have keys on a standard keyboard (most standard keyboards only have 101 keys so this is the only way of using all the 255 character available in common fonts).
This is a built in function of all computers that uses Microsoft OS's and even DOS, HDOS, EDOS, (well all the DOS's), and you can use them anywhere you can type anything from your keyboard, (emails, letters, databases, spread sheets, etc.) if you can type from the keyboard to any program you can use these characters in this manner.
I hope this help you out!
Aug 15, 2013 | E-Machines eMachines Desktop PC
How do I make the @ sign on the Mexican keyboard
You can use Windows Character Map, located in your Windows start menu under Accessories > System Tools to enter characters that may not be supported by your keyboard. Just open the Character Map window and click on the character you wish to use.from the listed options. Press Select to to choose, then Copy to move the character to the clipboard. Return to your document, place your cursor where you wish the character to appear and press Ctrl -V to insert it into your document.
Feb 23, 2011 | Acer Aspire One PC Notebook
How do I type an o with a line through it on an email address?
use the character map, programs / accessories / system tools / character map, choose the symbol you want and it will copy it, now just paste it where you want to use it, like this ?
Sep 30, 2010 | HP P2360AA Keyboard/Mouse
Asus X58Cseries with Windows Vista Basic has $ sign on 4 key but no pound sign. Any way of getting it? If not, I can live with it but would like to know either way.Cheers, Linda.
I'm an Asus X58C user in the UK and my keyboard is the same. I've not found an easy solution. The only way I can insert a £ character is this. Place your coursor where you want the character. Turn Numbers Lock on using the blue Fn and NumLk keys. Hold down the Alt key and then using the blue numbers keys type 0163. Release the Alt key and the £ character will appear. Turn Numbers Lock off using the blue Fn and NumLk keys again. Its laborious but it works, its how I typed it here. I also found out that if you hold down Ctrl and Alt and then press the 4 key, you type the euro character €. Hope this helps
Oct 06, 2009 | ASUS 90-A4C1K1000 Keyboard
Keyboard problem
Oct 09, 2008 | Microsoft Wireless Optical Desktop Comfort...
I don't know if it's gona be helpful, several times I had the same problem. I fixed this problem pressing different combination of keyboard key. I can't figure out exact one. On my laptop I tried combination with ALT key. This time it was my desktop keyboard, I tried every single combination with ALT and nothing... I was so mad I just press Caps Lock+Shift+Ctrl, my keyboard make a sound and guess what it helps @@@@@@@@@@
Mar 25, 2008 | Computers & Internet
Microsoft Wireless Optical Desktop Comfort Edition Logo
812 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
