Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
What oil do i use in the lower unit of a 1989 90 hp mercury outbord
    Top Expert:
  • Light Master
  • 50,380 Answers
Go to a marine store and get lower unit gear lube. it comes in a squeeze tune and just remove the plug and squirt it in . both screws need to be out tho upper one lets air out as you push new in lower .the put upper back in first keeping oil in till you put in lower plug
Posted on May 01, 2010
Other than head gasket how can water get into oil on 90 hp 4stroke merc ob
Water seldom gets into the engine oil, but more often in the lower gear case through the seals behind the propeller. If you have water in the oil of the head unit, then a blown head gasket is likely the cause.
Seems to be a known problem, and may just be the gasket between upper and lower unit.
https://www.google.com/search?q=water+in+oil+mercury++90+hp+4+stroke
Aug 29, 2017 | Cars & Trucks
I have a 110 mercury 9.5 hp not sure of year
This Mercury section is for cars not outboards. Web search for Salvage parts for outboards.
Jul 25, 2017 | Mercury Cars & Trucks
My 140 hp mercury outbord will only run if u take 1 spark plug out it does not mater witch plug it is
very unusual problem
need more information before I attempt to answer
is it a 4 stroke or 2 stroke , 4 cylinder in line or v engine
carby or efi --year and model would be a help as well
does it run ok at idle but fail at rpms when you take a plug out it runs well on the remaining cylinders
I have a germ of an idea but I need that information first to see it it is viable
comment , don't post as posts are not linked
Oct 02, 2016 | Mercury Cars & Trucks
I have 2004 mercury verado that is making ticking sound - I thought it was oil, but some one told me that it could be the lower unit... Any suggestion ? Thanks!
knocking is normally the lower unit
ticking is more associated with faulty hydraulic lifters , worn rocker arm bushes or worn rocker shafts
if there is amiss the it could be a spark jumping
Jul 01, 2015 | Mercury Cars & Trucks
I have a Mercury Verado 250 HP 2005. The problem is an oil loss. The only thing i am sure of it is engine oil and despite it was verified by Mercury dealer twice, they didn't find where it con
how many miles are on the car. it is normal for a care with a 100k or more to use a qt of oil about every 1500 to 2000 miles if you keep your foot in it. read your owners manual about how often you should check your oil. it is more often than you would think. think about using an oil additive that helps reduce oil consumption.
Nov 20, 2014 | Mercury Verado 6 Cyl. Engine Cover 200 225...
I need to change a water pump on a johnson 6hp outbord moater. modle no. 6R-70B
unbolt lower unit and you will be right there . shift rods vary so check where it is and how to unhook.
Mar 15, 2010 | Light Outboard Motor Boat Bass Fishing...
The fuel mixter for a 90 hp tracker force power serise outborde moter
Should be 50 to 1. a call to any mercury outboard dealer will give you the exact ratio
Mar 27, 2009 | Boating
Mercury 50 hp outboard
I actually thought it was down by the prop... i was wrong....
Pretty good diagram here.... look at part number 1
http://www.sterndrive.info/mercury-outboard-parts/60hp_to_125hp_component_layout.html
scroll down for the part cost and description.
Robert
Please take a moment to rate this solution.. thanks
Jan 23, 2009 | Computers & Internet
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
219 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Are you a Light Boating Expert? Answer questions, earn points and help others
